POV-Ray : Newsgroups : povray.advanced-users : alpha channel (+ua) makes media invisible? Server Time
25 Mar 2026 18:51:27 EDT (-0400)
  alpha channel (+ua) makes media invisible? (Message 1 to 7 of 7)
Subject: alpha channel (+ua) makes media invisible?
Date: 24 Jan 2010 12:13:41
Message: <4b5c7fc5$1@news.povray.org>
Maybe I'm missing something obvious, but whenever I try to render an
image with a transparent background, any emissive media that does not
have a solid object between it and the background just becomes
invisible, instead of partially transparent which is the intent.
Essentially, I'm trying to render an engine glow via emission, and it
works fine when I have a backdrop, but it disappears when I remove the
background.
minimal scene:
sphere{0,1
   texture{pigment{color rgbt 1}}
   hollow
   interior{
     media{
       emission <1,0,0>
       method 3
       intervals 1
       density{color rgb 0.5}
camera{location <0,2,-2> look_at <0,0,0>}
Setting -UA in the command line shows a red sphere, +UA is completely
transparent. Upon opening in photoshop, it shows that the red channel is
in fact correct, but the alpha channel is at 100% for the entire image.
Is there a way to get around this?
Subject: Re: alpha channel (+ua) makes media invisible?
Date: 24 Jan 2010 12:53:41
Message: <4b5c8925$1@news.povray.org>
> background.
> minimal scene:
> sphere{0,1
> hollow
> interior{
> media{
> emission <1,0,0>
> method 3
> intervals 1
Fact is that any emissive media IS totaly transparent by design. It adds
to whatever is behind, wighout filtering anything out.
What you can do:
Add some absorbing media with absorbtion<0,1,1>. Removes the blue and
green, leaving the red.
Add some scattering media and a light_source.
Change the pigment to rgbt<1,1,1,0.9> or rgbf<1,1,1,0.9>
Date: 24 Jan 2010 13:04:54
Message: <4b5c8bc6@news.povray.org>
  That's also the reason why emissive media is invisible against a white
background. Emissive media only adds to the passing rays, and adding something
to white results in white (after color clamping).
Date: 24 Jan 2010 13:11:28
Message: <4b5c8d50@news.povray.org>
  I wonder if it makes a difference when outputting to HDRI. (After all,
HDRI pixels are non-clamped.)
Date: 24 Jan 2010 13:31:15
Message: <4b5c91f3$1@news.povray.org>
> What you can do:
> Alain
Ahh, I see.
If I use what you said with the absorption media, it gives a bit of a
black halo around it, but I found that only using scattering seems to
produce comparable results to what I intended, though at a considerable
time cost. Oh well.
Thanks!
Date: 25 Jan 2010 20:24:17
Message: <4b5e4441$1@news.povray.org>
I think that it will show in that case. Have to try it.
Date: 26 Jan 2010 16:32:48
Message: <4b5f5f80$1@news.povray.org>
>>> something
> Alain
It does show, after you reduce the exposure, in programms made to handle
high dynamic range.
Minimal sample scene (render with +fh on the command line):
plane{-z,-10 pigment{checker rgb 1 rgb 0.1} finish{ambient 1}}
sphere{5*z,1.5 pigment{rgbt 1}
	interior{media{emission rgb x}}
	hollow}
It will also show on the surrounding objects whenever you use radiosity.
