![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: How to kill render speed (or to revive it again?)
Date: 24 Nov 2009 03:32:10
Message: <4b0b9a0a$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Certain combinations in a scene are sure to kill render speed, even with
multiple cores. In a scene I am working on I am using radiosity, focal blur,
and a (blurred) object with media containing scattering, some emission and
density. When reaching this particular object, the render drops down to a
crawl on my two core machine (using 3.7 beta 34). Maybe you have some smart
advice to give in order to boost up the render a bit? Here are the code
details:
Radiosity:
brightness 1
count 100
error_bound 1.0
gray_threshold 0.0
low_error_factor 0.4
minimum_reuse 0.015
nearest_count 1
recursion_limit 2
adc_bailout 0.005
media off
normal off
always_sample off
max_sample 1.0
pretrace_start 0.08
pretrace_end 0.004
media in object:
interior {
ior 1.45
media {
intervals 1
samples 10
scattering {1, rgb <0.2, 0.1, 0.1>}
#if (BallDensity)
emission <0.01, 0.01, 0.1>*0.5
density {
spherical
color_map {
[0.0 rgb <0.0, 0.1, 0.2>*0.15]
[0.5 rgb <0.4, 0.4, 0.2>]
[1.0 rgb <0.6, 0.6, 0.3>]
scale 1.5
warp {turbulence 2}
scale 0.9
#end //of BallDensity
As focal blur I use Edouard Poor's 35mm camrea macro with the following
settings:
Camera35mm_SetFocalSamples( 100 )
Camera35mm_SetFocalVariance( 1/10000 )
Camera35mm_Autofocus( CamLoc, CamEye, 38, 50, CentralObj )
Hope this helps to get an idea. Thanks for any advice.
All the best,
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: How to kill render speed (or to revive it again?)
Date: 24 Nov 2009 07:58:09
Message: <4b0bd861$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> blur, and a (blurred) object with media containing scattering, some
> emission and density. When reaching this particular object, the render
> drops down to a crawl on my two core machine (using 3.7 beta 34). Maybe
> you have some smart advice to give in order to boost up the render a bit?
> Here are the code details:
> Radiosity:
> brightness 1
> count 100
> error_bound 1.0
> gray_threshold 0.0
> minimum_reuse 0.015
> nearest_count 1
> recursion_limit 2
> adc_bailout 0.005
> media off
> normal off
> always_sample off
> max_sample 1.0
> pretrace_start 0.08
> pretrace_end 0.004
> media in object:
> interior {
> ior 1.45
> media {
> intervals 1
> samples 10
> #if (BallDensity)
> density {
> spherical
> color_map {
> scale 1.5
> warp {turbulence 2}
> scale 0.9
> settings:
Yeah, POV has always been about the trade-off of quality vrs
render time. Just make sure that your scene looks OK with lower
faster settings before commiting to a long high quality render.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 24 Nov 2009 11:08:07
Message: <4b0c04e7$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Tim Attwood" <tim### [at] anti-spam comcast net> schreef in bericht
news:4b0bd861$1@news.povray.org...
I think I can get away with still lower media samples in this case...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
