![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The following function transforms a sphere such that it is expanded
logarithmically along the y axis. What I would like to do next is to
expand a sphere based on its distance from the origin instead. Any
ideas? Of course, if the sphere is located a the origin like my example
it will still look like a sphere.
-Mike
#local Temp_fnc1 = function
1 - min(1, sqrt(x*x + y*y + z*z))
#local Temp_fnc3 = function
max(0,min(1,Temp_fnc1(x, log(y + 1) / log(2),z)))
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You'd need to (a) define the center of the sphere, (b) compute the
desired radius from the distance to the origin, (c) redefine your
Temp_fnc1 to take into account a radius, and (e) offset the parameters
to Temp_fnc1 by the center, as in:
#local Center = <...>; // (a)
#local Radius = log(vlength(Center)+1) / log(2); // (b)
1 - min(1, sqrt(x*x + y*y + z*z)/Radius) // (c)
Temp_fnc1(x-Center.x,y-Center.y,z-Center.z) // (d)
I guess this definition for Temp_fnc3 might run into problems though,
due to POV-Ray's general inability to use vector stuff in functions; you
may need to define temporary variables for the Center vector components,
as in:
#local CenterX = Center.x;
#local CenterY = Center.y;
#local CenterZ = Center.z;
Temp_fnc1(x-CenterX,y-CenterY,z-CenterZ)
Note that this will produce just a single sphere. To get multiples of
them, you might want to add multiple instances of that function, as in:
#macro Temp_Fnc(Center)
( Temp_fnc1(x-CenterX,y-CenterY,z-CenterZ) )
Temp_Fnc(<0,1,0>) +
Temp_Fnc(<0,3,0>) +
Temp_Fnc(<0,10,0>) +
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks. I'll try it out tonight or tomorrow.
> as in:
Yeah, I have trouble with the algebraic functions. I use another
program, called GeoGebra, to test out operations before I do them in
POVray. Unfortunately, this program uses algebraic functions in the
format of f(x) = 2 * x, which can sometimes be hard two convert to
POVray's format of 0 = 2 * x - y.
-Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I probably misunderstood that problem ... isn't the conversion just
subtracting the function value from both sides of the equations?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Christian Froeschlin wrote:
> SharkD wrote:
>> Unfortunately, this program uses algebraic functions in the format of
>> f(x) = 2 * x, which can sometimes be hard two convert to POVray's
In this case it is. However, consider the functions 0 = 2 * x - y^2 and
0 = 2 * x - log(y). Things begin to get a little tricky.
-Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
ok. I thought you wished to convert in the other direction.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> example it will still look like a sphere.
> as in:
> #end
> Temp_Fnc(<0,1,0>) +
> Temp_Fnc(<0,3,0>) +
I finally got around to trying this, and it didn't produce the results I
want. The main problem as I see it is that the Sphere parameter is
defined outside the function and stores only a single parameter.
-Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
