POV-Ray : Newsgroups : povray.advanced-users : Math help Server Time
13 Jun 2026 08:33:53 EDT (-0400)
  Math help (Message 1 to 7 of 7)
Subject: Math help
Date: 11 Sep 2009 23:38:40
Message: <4aab17c0$1@news.povray.org>
The following function transforms a sphere such that it is expanded
logarithmically along the y axis. What I would like to do next is to
expand a sphere based on its distance from the origin instead. Any
ideas? Of course, if the sphere is located a the origin like my example
it will still look like a sphere.
-Mike
#local Temp_fnc1 = function
     1 - min(1, sqrt(x*x + y*y + z*z))
#local Temp_fnc3 = function
     max(0,min(1,Temp_fnc1(x, log(y + 1) / log(2),z)))
Subject: Re: Math help
Date: 12 Sep 2009 05:08:57
Message: <4aab6529$1@news.povray.org>
You'd need to (a) define the center of the sphere, (b) compute the
desired radius from the distance to the origin, (c) redefine your
Temp_fnc1 to take into account a radius, and (e) offset the parameters
to Temp_fnc1 by the center, as in:
#local Center = <...>; // (a)
#local Radius = log(vlength(Center)+1) / log(2); // (b)
     1 - min(1, sqrt(x*x + y*y + z*z)/Radius) // (c)
     Temp_fnc1(x-Center.x,y-Center.y,z-Center.z) // (d)
I guess this definition for Temp_fnc3 might run into problems though,
due to POV-Ray's general inability to use vector stuff in functions; you
may need to define temporary variables for the Center vector components,
as in:
#local CenterX = Center.x;
#local CenterY = Center.y;
#local CenterZ = Center.z;
     Temp_fnc1(x-CenterX,y-CenterY,z-CenterZ)
Note that this will produce just a single sphere. To get multiples of
them, you might want to add multiple instances of that function, as in:
#macro Temp_Fnc(Center)
   ( Temp_fnc1(x-CenterX,y-CenterY,z-CenterZ) )
   Temp_Fnc(<0,1,0>) +
   Temp_Fnc(<0,3,0>) +
   Temp_Fnc(<0,10,0>) +
Date: 12 Sep 2009 22:23:17
Message: <4aac5795$1@news.povray.org>
Thanks. I'll try it out tonight or tomorrow.
> as in:
Yeah, I have trouble with the algebraic functions. I use another
program, called GeoGebra, to test out operations before I do them in
POVray. Unfortunately, this program uses algebraic functions in the
format of f(x) =  2 * x, which can sometimes be hard two convert to
POVray's format of 0 = 2 * x - y.
-Mike
Date: 13 Sep 2009 14:23:57
Message: <4aad38bd@news.povray.org>
I probably misunderstood that problem ... isn't the conversion just
subtracting the function value from both sides of the equations?
Date: 13 Sep 2009 15:29:07
Message: <4aad4803$1@news.povray.org>
Christian Froeschlin wrote:
> SharkD wrote:
>> Unfortunately, this program uses algebraic functions in the format of
>> f(x) =  2 * x, which can sometimes be hard two convert to POVray's
In this case it is. However, consider the functions 0 = 2 * x - y^2 and
0 = 2 * x - log(y). Things begin to get a little tricky.
-Mike
Date: 13 Sep 2009 20:24:52
Message: <4aad8d54@news.povray.org>
ok. I thought you wished to convert in the other direction.
Date: 24 Sep 2009 22:53:19
Message: <4abc309f$1@news.povray.org>
>> example it will still look like a sphere.
> as in:
> #end
>   Temp_Fnc(<0,1,0>) +
>   Temp_Fnc(<0,3,0>) +
I finally got around to trying this, and it didn't produce the results I
want. The main problem as I see it is that the Sphere parameter is
defined outside the function and stores only a single parameter.
-Mike
