POV-Ray : Newsgroups : povray.advanced-users : Macro load optimization Server Time
10 Jan 2025 05:56:14 EST (-0500)
  Macro load optimization (Message 1 to 5 of 5)
Subject: Macro load optimization
Date: 5 Sep 2009 11:44:00
Message: <4aa28740$1@news.povray.org>
I understand that whenever a macro is called that is not in the main
scene file, the .inc must be opened for every call, thus the speed
improvement by copying often used macros to the scene file.
However, how is it handled when a macro calls another macro?
Example:
scene.pov has no macros defined, includeA.inc has MacroA defined.
Scene calls MacroA 100 times, so includeA.inc is opened and closed 100
times.
scene.pov has no macros defined, includeA.inc has MacroA and MacroB defined.
Scene calls MacroA 100 times, and MacroA then calls MacroB 10 times
within itself.
My question: Is includeA.inc opened 100 times still, or is it then
opened 1000 times?
Subject: Re: Macro load optimization
Date: 5 Sep 2009 17:42:51
Message: <4aa2db5b$1@news.povray.org>
> Example:
> times.
> defined.
> within itself.
> opened 1000 times?
No.
The source file is only opened and closed when you call it from another
file.
Also, if a macro from an include file calls a macro from the main file
or another include from whithc it was called, then NO file gets to be
open/red/closed.
Call a macro from the SAME file = no additional file transaction.
Call a macro from a file upper in the calling list = still no additional
file transaction.
Example 1: A macro from an include file use a macro from the main file.
Example 2: A macro from an include file, included by another include
file, that use a macro from the preceding include (the one that caused
it's inclusion).
Date: 6 Sep 2009 03:17:03
Message: <4aa361ef$1@news.povray.org>
As long as a macro is called from whichever file it is defined in -
whether it is the main scene file or an include file - there is no file
opening/closing overhead involved.
Date: 8 Sep 2009 13:27:35
Message: <4aa69407$1@news.povray.org>
> file.
> or another include from which it was called, then NO file gets to be
> open/read/closed.
> file transaction.
> it's inclusion).
> Alain
Thanks, didn't know about the hierarchy part for not opening files
higher in the chain.
One further question:
The main file includes IncludeA and IncludeB. IncludeB has a macro which
uses a macro from within IncludeA.
//-----main.pov
#include "A.inc"
#include "B.inc"
MacroB(param)
//-----end main.pov
//-----A.inc
#macro MacroA(param) //stuff
//-----end A.inc
//-----B.inc
#macro MacroB(param)
   //stuff
   MacroA(param)
//-----end B.inc
What is the file I/O done in this case?
Chris
Date: 8 Sep 2009 19:14:14
Message: <4aa6e546$1@news.povray.org>
>> another file.
>> open/read/closed.
>> it's inclusion).
>> Alain
> //-----main.pov
> #include "A.inc"
> #include "B.inc"
> MacroB(param)
> //-----end main.pov
> //-----A.inc
> #end
> //-----end A.inc
> //-----B.inc
>   //stuff
>   MacroA(param)
> #end
> //-----end B.inc
> Chris
Every time that the macro from B.inc is called, B.inc need to be
accessed. Then, every time that macro uses the macro from A.inc, A.inc
will get accessed.
So, each time that MacroB() is used, you'll end up accessing BOTH includes.
MUCH beter to copy MacroA() into B.inc or the main file.
