POV-Ray : Newsgroups : povray.advanced-users : Pattern showing *change* in slope Server Time
10 Jan 2025 06:16:58 EST (-0500)
  Pattern showing *change* in slope (Message 1 to 10 of 26)
Subject: Pattern showing *change* in slope
Date: 28 Aug 2009 06:52:54
Message: <4a97b706$1@news.povray.org>
How can I create a pattern that shows the *change* in slope of a
heightfield. I.e., brighter where the "curvature" is greater.
Thanks!
-Mike
Subject: Re: Pattern showing *change* in slope
Date: 28 Aug 2009 07:25:22
Message: <4a97bea2$1@news.povray.org>
You can create this from the image you use for the height field
To begin with, make a pigment from the image; make from that a function F.
Now, create a function G computing the curvature from five function
values from F, spaced apart by (at least) 1/BITMAP_SIZE, to compute the
"difference in difference" both vertically and horizontally:
#declare D = 1/BITMAP_SIZE; // insert actual size of your bitmap here
#declare Sqr = function(x) { x*x }
#declare G = function(x,y,z) {
   sqrt(
     Sqr( F(x-D,y,z) + F(x+D,y,z) - 2*F(x,y,z) ) // squared curvature X
     Sqr( F(x,y-D,z) + F(x,y-D,z) - 2*F(x,y,z) ) // squared curvature Y
finally, apply this function as a pattern to your height field.
Date: 28 Aug 2009 07:40:32
Message: <4a97c230@news.povray.org>
I used that for my hf2iso experiment:
global_settings{hf_gray_16}
#include "functions.inc"
// file to extract slope from
#declare hf_file="your_hf_here"
// sloped texture with autoilluminated finish
#declare t_terrain_slope=
texture{
  pigment{
   slope y
   color_map{
    [0.00 rgb 0]
    [0.50 rgb 1]
    [0.67 rgb 1]
    [0.75 rgb 0]
    [1.00 rgb 0]
  finish{brilliance 0 ambient 1}
// create a heightfield from the bitmat
#declare terrain=
height_field{
  tga hf_file
  translate -.5
  scale <2,1,2>
  texture{t_terrain_slope}
object{terrain}
// take a square shot
camera{
  orthographic
  location <0,0,-1>
  up 1*y right 1*x
  angle 90
  look_at 0
  rotate 90*x
Jaime
Date: 28 Aug 2009 07:45:22
Message: <4a97c352@news.povray.org>
> texture{
>   pigment{
>    slope y
  That shows the slope of the heightfield, not the *change* in slope,
which is a bit more involved (it would require the derivative of the
function which indicates the slope of the heightfield; since the slope
function is the derivative of the heightfield function, the change in
slope would thus be the double derivative of the heightfield function).
  Maybe the original poster really wanted to actually see the slope,
rather than the change in slope, in which case your answer would be
the correct one.
Date: 28 Aug 2009 09:38:51
Message: <4a97ddeb@news.povray.org>
> the correct one.
Nope. I want the double derivative.
-Mike
Date: 28 Aug 2009 09:39:53
Message: <4a97de29$1@news.povray.org>
>   sqrt(
I'll give it a shot, thanks.
-Mike
Date: 28 Aug 2009 10:33:34
Message: <4a97eabe$1@news.povray.org>
>> texture{
>>   pigment{
>>    slope y
> the correct one.
Is there a function in POV that will allow me to automatically take the
derivative of another function?
-Mike
Date: 28 Aug 2009 11:12:05
Message: <4a97f3c5@news.povray.org>
  Then your only option is to generate the heightfield using a function
and then use the double derivative of that function with respect to x and
another with respect to y and combine them appropriately to create the
desired pattern, which you then can use to create the pigment.
Date: 28 Aug 2009 11:13:36
Message: <4a97f41f@news.povray.org>
  Calculating the derivative of a function analytically is not trivial
and has such low demand that povray obviously doesn't offer such a thing.
  A numerical approximation could be easier, but still the demand is so
low that no such luck.
  But I think the user-defined functions are expressive enough for you to
do it in SDL.
Date: 28 Aug 2009 11:52:04
Message: <4a97fd24$1@news.povray.org>
> do it in SDL.
