POV-Ray : Newsgroups : povray.advanced-users : Pattern showing *change* in slope Server Time
9 Jun 2026 09:52:28 EDT (-0400)
  Pattern showing *change* in slope (Message 7 to 16 of 26)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Pattern showing *change* in slope
Date: 28 Aug 2009 10:33:34
Message: <4a97eabe$1@news.povray.org>
Warp wrote:
> Jaime Vives Piqueres <jai### [at] ignoranciaorg> wrote:
>> // sloped texture with autoilluminated finish
>> #declare t_terrain_slope=
>> texture{
>>   pigment{
>>    slope y
>   That shows the slope of the heightfield, not the *change* in slope,
> which is a bit more involved (it would require the derivative of the
> function which indicates the slope of the heightfield; since the slope
> function is the derivative of the heightfield function, the change in
> slope would thus be the double derivative of the heightfield function).
>   Maybe the original poster really wanted to actually see the slope,
> rather than the change in slope, in which case your answer would be
> the correct one.
Is there a function in POV that will allow me to automatically take the
derivative of another function?
-Mike
Date: 28 Aug 2009 11:12:05
Message: <4a97f3c5@news.povray.org>
SharkD <mik### [at] gmailcom> wrote:
> Nope. I want the double derivative.
  Then your only option is to generate the heightfield using a function
and then use the double derivative of that function with respect to x and
another with respect to y and combine them appropriately to create the
desired pattern, which you then can use to create the pigment.
Date: 28 Aug 2009 11:13:36
Message: <4a97f41f@news.povray.org>
  Calculating the derivative of a function analytically is not trivial
and has such low demand that povray obviously doesn't offer such a thing.
  A numerical approximation could be easier, but still the demand is so
low that no such luck.
  But I think the user-defined functions are expressive enough for you to
do it in SDL.
Date: 28 Aug 2009 11:52:04
Message: <4a97fd24$1@news.povray.org>
> do it in SDL.
Date: 28 Aug 2009 11:52:30
Message: <4a97fd3e@news.povray.org>
> do it in SDL.
OK, so how would I go about doing it?
-Mike
Date: 28 Aug 2009 12:05:34
Message: <4a98004e$1@news.povray.org>
clipka wrote:
> SharkD schrieb:
>> How can I create a pattern that shows the *change* in slope of a
>> heightfield. I.e., brighter where the "curvature" is greater.
> You can create this from the image you use for the height field
> To begin with, make a pigment from the image; make from that a function F.
> Now, create a function G computing the curvature from five function
> values from F, spaced apart by (at least) 1/BITMAP_SIZE, to compute the
> "difference in difference" both vertically and horizontally:
OK, here's what I have:
//START
#local hf_function1 = function {pigment {hf_pigment3}}
#local dv_D = 1/1024;
#local dv_Sqr = function(x) {x * x}
#local dv_G = function(x,y,z)
	sqrt
		dv_Sqr(hf_function1(x - dv_D,y,z) + hf_function1(x + dv_D,y,z) - 2 *
hf_function1(x,y,z))
		dv_Sqr(hf_function1(x,y - dv_D,z) + hf_function1(x,y - dv_D,z) - 2 *
//END
However, I get the error: "Parse Error: Expected '.', + found instead"
-Mike
Date: 28 Aug 2009 12:09:26
Message: <4a980135@news.povray.org>
> > do it in SDL.
http://en.wikipedia.org/wiki/Derivative
Date: 28 Aug 2009 12:10:02
Message: <4a98015a$1@news.povray.org>
clipka wrote:
>   sqrt(
>     Sqr( F(x-D,y,z) + F(x+D,y,z) - 2*F(x,y,z) ) // squared curvature X
>     Sqr( F(x,y-D,z) + F(x,y-D,z) - 2*F(x,y,z) ) // squared curvature Y
Also, there's supposed to be an operator between the first and second
instances of the function "Sqr". Which operator is it?
-Mike
Date: 28 Aug 2009 12:16:08
Message: <4a9802c8@news.povray.org>
Please point me to the part where it describes POV SDL.
Thanks.
-Mike
Date: 28 Aug 2009 12:31:00
Message: <4a980644$1@news.povray.org>
SharkD schrieb:
> clipka wrote:
>>   sqrt(
Oops, sorry - should be "+".
The idea behind it is that each terms inside the Sqr() computes the
curvature in a particular dimension; if you interpret that as a vector,
the sqrt(Sqr()+Sqr()) computes the "absolute" of the curvature.
