POV-Ray : Newsgroups : povray.advanced-users : Pattern showing *change* in slope Server Time
9 Jun 2026 08:02:00 EDT (-0400)
  Pattern showing *change* in slope (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: Pattern showing *change* in slope
Date: 28 Aug 2009 11:52:30
Message: <4a97fd3e@news.povray.org>
Warp wrote:
>   But I think the user-defined functions are expressive enough for you to
> do it in SDL.
OK, so how would I go about doing it?
-Mike
Date: 28 Aug 2009 12:05:34
Message: <4a98004e$1@news.povray.org>
clipka wrote:
> SharkD schrieb:
>> How can I create a pattern that shows the *change* in slope of a
>> heightfield. I.e., brighter where the "curvature" is greater.
> You can create this from the image you use for the height field
> To begin with, make a pigment from the image; make from that a function F.
> Now, create a function G computing the curvature from five function
> values from F, spaced apart by (at least) 1/BITMAP_SIZE, to compute the
> "difference in difference" both vertically and horizontally:
OK, here's what I have:
//START
#local hf_function1 = function {pigment {hf_pigment3}}
#local dv_D = 1/1024;
#local dv_Sqr = function(x) {x * x}
#local dv_G = function(x,y,z)
	sqrt
		dv_Sqr(hf_function1(x - dv_D,y,z) + hf_function1(x + dv_D,y,z) - 2 *
hf_function1(x,y,z))
		dv_Sqr(hf_function1(x,y - dv_D,z) + hf_function1(x,y - dv_D,z) - 2 *
//END
However, I get the error: "Parse Error: Expected '.', + found instead"
-Mike
Date: 28 Aug 2009 12:09:26
Message: <4a980135@news.povray.org>
SharkD <mik### [at] gmailcom> wrote:
> > do it in SDL.
http://en.wikipedia.org/wiki/Derivative
Date: 28 Aug 2009 12:10:02
Message: <4a98015a$1@news.povray.org>
clipka wrote:
>   sqrt(
>     Sqr( F(x-D,y,z) + F(x+D,y,z) - 2*F(x,y,z) ) // squared curvature X
>     Sqr( F(x,y-D,z) + F(x,y-D,z) - 2*F(x,y,z) ) // squared curvature Y
Also, there's supposed to be an operator between the first and second
instances of the function "Sqr". Which operator is it?
-Mike
Date: 28 Aug 2009 12:16:08
Message: <4a9802c8@news.povray.org>
Please point me to the part where it describes POV SDL.
Thanks.
-Mike
Date: 28 Aug 2009 12:31:00
Message: <4a980644$1@news.povray.org>
SharkD schrieb:
> clipka wrote:
>>   sqrt(
Oops, sorry - should be "+".
The idea behind it is that each terms inside the Sqr() computes the
curvature in a particular dimension; if you interpret that as a vector,
the sqrt(Sqr()+Sqr()) computes the "absolute" of the curvature.
Date: 28 Aug 2009 12:35:40
Message: <4a98075c$1@news.povray.org>
> 2 * hf_function1(x,y,z))
Sorry, I forgot that with that hf_function1 being a pigment function,
you'll need to evaluate a particular color component, so instead of
     hf_function1(...)
you need to write:
     hf_function1(...).grey
(or .red, .green or .blue, but if I'm not mistaken the height_field
object uses the combined grey value as well, so the same should be used
as the basis for the curvature computations.)
Date: 28 Aug 2009 12:43:37
Message: <4a980939$1@news.povray.org>
>     hf_function1(...)
> you need to write:
Thanks! However, all I see is black. Here are the relevant portions of
my scene.
-Mike
//START
#local hf_pigment1 = pigment
	image_map {png "hf_big.png"}
	rotate x * 180		// flipped
#local hf_function1 = function {pigment {hf_pigment1}}
	sqrt
		dv_Sqr(hf_function1(x - dv_D,y,z).gray + hf_function1(x +
dv_D,y,z).gray - 2 * hf_function1(x,y,z).gray)
		dv_Sqr(hf_function1(x,y - dv_D,z).gray + hf_function1(x,y -
dv_D,z).gray - 2 * hf_function1(x,y,z).gray)
height_field
	function 1024, 1024 {hf_function1(x,y,z).gray}
	smooth
	texture
		pigment
			function {dv_G(x,y,z)}
			color_map
				[0 rgb 0]
				[1 rgb 1]
		finish {ambient 1}
	translate <-1/2,0,-1/2,>
//END
Date: 28 Aug 2009 13:01:54
Message: <4a980d82$1@news.povray.org>
> my scene.
Ah, yes... looks like I forgot that you need to multiply the sqrt() term
with the image's size again (and then scale to taste).
Date: 28 Aug 2009 18:25:00
Message: <web.4a9858dd38d8f2bb457ff4630@news.povray.org>
> my scene.
> -Mike
> //START
>  sqrt
The dy component is being subtracted twice, when it should be subtracted for one
value, then added.
    1/dv_D *
    sqrt
        dv_Sqr(   hf_function1(x - dv_D,y,z).gray
                + hf_function1(x + dv_D,y,z).gray
                - 2 * hf_function1(x,y,z).gray )
       +dv_Sqr(   hf_function1(x,y - dv_D,z).gray
                + hf_function1(x,y + dv_D,z).gray
Also, isn't that the first derivative (i.e. slope), not the second?  The
function is roughly analogous to what you would want to do with, say, the
surface normal of the object (i.e. measure the normal's rate of change), or the
values that are returned from the slope pattern.
If you use this directly as a pigment, you should clip it between 0 and 1.
Personally, I would also probably rotate the image and evaluate in the xz plane
because it is easier for me to think of, but either way will work.
-Reactor
