POV-Ray : Newsgroups : povray.advanced-users : "Unwrap" a mesh object Server Time
13 Jun 2026 08:32:14 EDT (-0400)
  "Unwrap" a mesh object (Message 1 to 3 of 3)
Subject: "Unwrap" a mesh object
Date: 10 Apr 2009 20:35:23
Message: <49dfe5cb$1@news.povray.org>
I know it's possible to "unwrap" 3D meshes made in other applications
such that the resulting object is completely flat. See this for example:
http://paperstarships.tengun.net/
However, is it also possible to do this with POV-Ray objects
(specifically, polygonal or mesh-based ones)? The reason I ask is that I
have a mesh object with materials and so forth assigned to it, and I
would like to "fabricate" a texture for it that I can then import into
another program.
-Mike
Subject: Re: "Unwrap" a mesh object
Date: 10 Apr 2009 21:55:01
Message: <web.49dff7b2e8063569722e13220@news.povray.org>
> another program.
If I understand your problem correctly, you have a POV mesh object, with a POV
procedural texture, both of which you want to import into some other modeller.
I actually did (almost) exactly that for a TC-RTC shot:
http://www.tc-rtc.co.uk/imagenewdisplay/stills/index185.html
This is a checker-pattern composition of a POV-Ray shot and a rasterized version
of the same scene. Note the marble textures The marble textures on the pawns:
These are genuine POV textures, which for the rasterized pieces had to be
"snapshot" into UV-mappable texture images.
Here's the workflow I used:
* My models were initially Wings 3D models; if you only have the POV meshes,
PoseRay will probably help you extract them to, say, .obj format.
* Next step was to create a UV mapping for the models; if your models already
have UV co-ordinates attached, then you can skip this one. Otherwise, Wings 3D
or similar programs will happily support you with the task of generating a more
or less low-distortion UV mapping. When done, export to .obj format again.
* Now we're heading for the fun part: I wrote a simple C# program that would
parse an .obj file, and generate from it a POV scene with a host of triangles:
Each placed normally in 3D space as described in the .obj files, equipped with
the desired texture, and then individually pushed around and distorted to end
up at the UV co-ordinates in the XY plane. Add an orthographic camera, render
at high resolution, and voila - POV spits out a snapshot of the texture, ready
to be UV-mapped to your .obj!
* As one last step, to make sure that no seams will be visible, load the texture
into an image processing software, and "bleed" the triangle colours into the
background.
If you like, I'd be willing to make the C# program available.
Date: 11 Apr 2009 00:19:59
Message: <49e01a6f$1@news.povray.org>
>> another program.
> background.
Awesome! That is *exactly* what I had in mind. Any chance of releasing
that C# program? :)
-Mike
PS: I wonder how we could handle all the other possible OBJ texture
types, such as specularity, glow, etc.?
