POV-Ray : Newsgroups : povray.advanced-users : mri data as isosurface? Server Time
28 Sep 2024 08:10:14 EDT (-0400)
  mri data as isosurface? (Message 1 to 3 of 3)
Subject: mri data as isosurface?
Date: 27 Jan 2009 11:52:36
Message: <497f3bd4$1@news.povray.org>
Hello,
I recall that many years ago, back when isosurfaces were part of the
"isosurface patch", there was a demo image using MRI data I think...
Does anyone remember how to do that, or have that file?
I just had an MRI last night, and I think it would be cool to render my
brain.
ian
Subject: Re: mri data as isosurface?
Date: 27 Jan 2009 12:28:51
Message: <NNqllCBQO0fJFwmr@econym.demon.co.uk>
Wasn't it [GDS|Entropy] who wrote:
>Hello,
>brain.
I don't know how that would have worked with the patch, but the official
isosurface code added the ability to use any pattern in an isosurface
function, so if you can obtain the raw data and convert it to a DF3 file
you can write things like
#declare F=function{ pattern{
      density_file df3 "brain.df3"
      interpolate 1 }
isosurface {function { 0.05 - F(x,y,z) }
Mike Williams
Gentleman of Leisure
Date: 28 Jan 2009 10:28:18
Message: <49807992$1@news.povray.org>
Hmm...
Well apparently my data is in DICOM format.
I used a program called MRIco found here: http://www.sph.sc.edu/comd/rorden/
to convert it to Analyze format.
Apparently I will need to use the TGA to DF3 converter in p.b.u to convert
TGAs to DF3....as there are no other converters that I can locate.
I did find info and code to patch POV to support HDF as isosurface, found
here: http://www.linuxjournal.com/article/7486
fwiw,
ian
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
news:NNq### [at] econymdemoncouk...
>>Hello,
>>brain.
>      interpolate 1 }
> Mike Williams
