POV-Ray : Newsgroups : povray.advanced-users : height field generation Server Time
26 Mar 2026 21:50:11 EDT (-0400)
  height field generation (Message 1 to 5 of 5)
Subject: height field generation
Date: 30 Sep 2008 00:24:01
Message: <48e1a9e1$1@news.povray.org>
I found the Perl::GD module convenient for generating a height field.  For example:
#! /usr/bin/perl
use strict;
use GD::Simple;
# create a new image
my npoints = 256;
my $image = GD::Simple->new($npoints, $npoints);
# .. (clipped) a 2-d array f is populated with values, with maximal value fmax
for my $nx ( 0 .. $npoints - 1) {
   for my $ny ( 0 .. $npoints - 1) {
     my $f = int(255 * $f[$nx]->[$ny] / $fmax);
     my $color = $image->colorExact($f, $f, $f);
     $color = $image->colorAllocate($f, $f, $f)
       if ($color < 0);
     die
       if ($color < 0);
     $image->setPixel($nx,$ny,$color);
open FOUT, ">heightfield.png"
   or die;
print FOUT $image->png;
Subject: Re: height field generation
Date: 30 Sep 2008 09:02:14
Message: <48e22356$1@news.povray.org>
If you have a function to generate the height
field, you can also use it in SDL directly:
#declare npoints = 512;
#declare f       = function {0.1+0.1*sin(x*20)};
#declare fmax    = 0.2;
height_field
   function npoints, npoints {f(x,0,y)/fmax}
Date: 30 Sep 2008 11:24:09
Message: <48e24499$1@news.povray.org>
> height_field
Thanks!
A disadvantage of the Perl GD module is I can't figure out how to generate 16-bit PNG
with it, which is a real issue, even with "smooth".  The advantage, of course, is you
needn't reevaluate the function each time the code is executed, depending on the
function complexity.
Dan
Date: 30 Sep 2008 19:08:30
Message: <48e2b16e$1@news.povray.org>
Dan Connelly wrote:
> The advantage, of course, is you needn't reevaluate the function each
> time the code is executed, depending on the function complexity.
You can also use a POV script to generate a 16-bit PNG
based on a function, either by defining a function pigment
or by rendering the heigth_field itself using hf_gray_16.
Date: 1 Oct 2008 05:20:01
Message: <web.48e3404ddfbf1b63fddaa4670@news.povray.org>
> 16-bit PNG with it, which is a real issue, even with "smooth".  The advantage,
> of course, is you needn't reevaluate the function each time the code is
I recommend the ppm or, in the case of heightfields, pgm format instead of png.
It is very easy to create, with as many bits as you want.
Povray does support ppm, but I am unsure whether bit-depths higher than 16
are supported. Also, I am unsure if pgm is supported, but you can always use
ppm im case it is not.
See http://netpbm.sourceforge.net/doc/#formats
Best regards,
  Mark Weyer
