POV-Ray : Newsgroups : povray.advanced-users : Pigment functions... Server Time
12 Oct 2025 06:40:21 EDT (-0400)
  Pigment functions... (Message 1 to 10 of 17)
Subject: Pigment functions...
Date: 9 Sep 2006 16:07:49
Message: <45031f15@news.povray.org>
Fact: POV-Ray can use an image as a pigment.
Fact: POV-Ray can use a pigment as a function.
Fact: POV-Ray can use a function as a pigment.
In spite of the above, I can't seem to get POV-Ray to load an image as a
pigment, turn the pigment into a function, and then turn the function
back into a pigment again. (I want to **** around with the coordinates.)
Any hints?
Subject: Re: Pigment functions...
Date: 9 Sep 2006 16:39:41
Message: <4503268d@news.povray.org>
> Any hints?
Does this help? It's approximated using the default assumed_gamma, and
may not be perfect, but it's a start:
#declare img =
  pigment{
   image_map{
    png"povmap.png"
   scale<320,200,1>/320
#declare f_img =
function{
  pigment{ img }
#declare option_1 = // no color
  pigment{
   function{ f_img(x,y,z).grey }
#declare option_2 = // approximated colors
  pigment{
   average
   pigment_map{
    [1 function{ f_img(x,y,z).x } color_map{[0 rgb 0][1 rgb x*1.55]} ]
    [1 function{ f_img(x,y,z).y } color_map{[0 rgb 0][1 rgb y*1.55]} ]
    [1 function{ f_img(x,y,z).z } color_map{[0 rgb 0][1 rgb z*1.55]} ]
plane{z,0
  pigment{option_2}
  finish{ambient 1}
Date: 9 Sep 2006 16:48:40
Message: <450328a8$1@news.povray.org>
>> Any hints?
I see... So a pigment function has to be colour_mapped? That would
explain why it's not working.
Ah, but I can extract all three colour components, turn each into a
pigment, and average them together... ingenius!
OK, I'll give that a go.
PS. I'm not using any gamma correction at all - I don't know what it is
or how it works. So...
Date: 9 Sep 2006 17:46:38
Message: <4503363e@news.povray.org>
Anytime I've tried to apply a color_map to a function pigment, it never
looked right. I have just recently discovered the .x, .y, .z extensions
to functions.
Let me know how it works for you.
It lightens/darkens an image. It helps to fix dark scenes, or washed-out
scenes (which are less likely with POV).
~Sam
Date: 11 Sep 2006 08:30:01
Message: <web.45055691a29fb3bbc150d4c10@news.povray.org>
Orchid XP v3 <voi### [at] devnull> wrote:
> >> Any hints?
Yes, functions don't carry vectors.  Here is a simple example of how I use
it (I use the .red, .green and .blue filters rather than .x, .y and .z):
//START
  #local PIMAGE = function {pigment{image_map {sys ImageMap interpolate 2}}}
  #local FRd=function(x,y) {PIMAGE(x,y,0).red }
  #local FGn=function(x,y) {PIMAGE(x,y,0).green }
  #local FBl=function(x,y) {PIMAGE(x,y,0).blue }
      box{<0,0,0>,<1,1,1>
        texture{average
          texture_map{
              [pigment{function{FRed(x,y)} color_map{[0 rgb 0][1 rgb
<1,0,0>]}} finish {ambient 3 diffuse 0}]
              [pigment{function{FGrn(x,y)} color_map{[0 rgb 0][1 rgb
<0,1,0>]}} finish {ambient 3 diffuse 0}]
              [pigment{function{FBlu(x,y)} color_map{[0 rgb 0][1 rgb
<0,0,1>]}} finish {ambient 3 diffuse 0}]
//END
-tgq
Date: 11 Sep 2006 08:54:39
Message: <45055c8e@news.povray.org>
  Actually function can handle and return vectors. These are called
vector-functions. The problem is that at least currently vector-functions
can't be used as pigments directly. You can only extract the components
of the vector returned by the function (or assign the vector to an
identifier, of course).
Date: 12 Sep 2006 00:20:00
Message: <web.4506337aa29fb3bb40e82a460@news.povray.org>
True...and very useful...but OOH you'll hear loud cries of dissent
from many in the POV community about "abusing gamma."
(I massage assumed_gamma all the time ;-) Just another
artistic tool, IMHO.)
Ken W.
Date: 12 Sep 2006 18:58:12
Message: <45073b84@news.povray.org>
> Ken W.
Sometimes the only way to get enough color-saturation in a scene is to
bump up the assumed gamma and brighten the lights. Or you could put a
rgbt<1,1,1,2> plane in front of everything....
~Sam
Date: 12 Sep 2006 23:00:01
Message: <web.45077215a29fb3bbdda07a910@news.povray.org>
So THAT'S how it's done. Thanks, Samuel.  VERY useful.
The color_map entry [0 rgb 0] is kind of a mystery to me, though.
What does color_map{[0 rgb 0][1 rgb x*1.55]}, for example, actually tell
POV-Ray to do, in this case? (I do understand the x*1.55 part.)
Ken W.
Date: 12 Sep 2006 23:14:59
Message: <450777b3$1@news.povray.org>
Your welcome!
An image has three color channels which range between 0 & 255.  All the
color_map is telling POV to do is to apply a color range from 0 to 1.55
(255*1.5)for the red channel. All the channels are combined to make a
complete rgb image.
~Sam
