POV-Ray : Newsgroups : povray.advanced-users : I really really want n-sided bezier patches... Server Time
18 May 2026 00:01:52 EDT (-0400)
  I really really want n-sided bezier patches... (Message 21 to 28 of 28)
Subject: Re: I really really want n-sided bezier patches...
Date: 23 Aug 2002 14:41:01
Message: <3d6681bd@news.povray.org>
Micha Riser wrote:
>> As I assumed, it was something with how the w
>> value was calculated. Apparently, if 1-2*u*v is
>> smaller than 1.0, then no division should happen
>> at all (or a division by 1). I found out by
>> coincidence more or less, so don't ask me why...
> NOO! What you get is no longer a bezier patch!
> You lose the C-1 continuity at the borders!
Argh, sighhhh.
That's what I get from changing variables at random...
Maybe there's still hope. With only a 200% increase in parse time we
could calculate each point three times, each with a different edge being
the w edge. Then average those three points.
What? What's wrong with that??
Rune
rune|vision:  http://runevision.com (updated July 12)
POV-Ray Ring: http://webring.povray.co.uk
Date: 23 Aug 2002 18:32:26
Message: <3d66b7fa@news.povray.org>
Try it, I could not bring this idea working. I do not really understand
what causes the different sizes of the triangles.
http://objects.povworld.org - the POV-Ray Objects Collection
Date: 24 Aug 2002 12:03:29
Message: <3d67ae51$1@news.povray.org>
Micha Riser wrote:
>> in parse time we could calculate each point three
>> times, each with a different edge being the w edge.
> not really understand what causes the different
I think I have a solution, and this time it might even work correctly...
I did some #debug work and I found out that the w value is indeed
"skewed" and that changing the epsilon1 value to 1.0 makes it
"straight".
However, when u, v and w are all straight, the patch does not join up
smoothly with other patches. Making any one of the u, v or w value
skewed makes it smooth again, and it doesn't matter which of them it is.
So instead of having one of them completely skewed, I tried making all
of them 1/3 skewed and 2/3 straight. It seems to work. The patch seems
to be smooth, and the triangles are distributed evenly. Also, there is
practically no slow-down, as the averaging part is done to the u, v and
w values before the actual points are calculated.
I'll post the code when it's cleaned up.
Rune
Date: 26 Aug 2002 15:13:56
Message: <3d6a7df3@news.povray.org>
OK, sound good. I will have a look at it when I get some time. I will try
the 5-sided (and eventually the 6-sided) then too.
- Micha
Date: 26 Aug 2002 17:16:43
Message: <3d6a9abb$1@news.povray.org>
> some time. I will try the 5-sided (and eventually
Sounds good! :)
Rune
Date: 27 Aug 2002 15:01:07
Message: <Xns9277D68261F9Cseed7@povray.org>
in news:3d6571f8$1@news.povray.org Rune wrote:
> Actually, uv-mapping should be easy to make, as the whole patch seems to
> be based on uv coordinates in the first place.
More or less falling in the middle of a thread, just back from the UK
Gathering. Just before I left, I plugged Micha's equations into param.inc,
it produces mesh2 and does uv-mapping, not sure though if the mapping is
as you want it.
Ingo
Date: 27 Aug 2002 15:29:54
Message: <3d6bd332$1@news.povray.org>
> just back from the UK Gathering. Just before I
> though if the mapping is as you want it.
I'd like to have a look. I already made the code generate a mesh2 and
for the mapping I plan to work on some non-linear mapping, but to see
alternative solutions can never hurt. There might be some things that
could be optimized or something like that. :)
Rune
Date: 27 Aug 2002 16:31:05
Message: <Xns9277E5C5499C9seed7@povray.org>
Posted the scene as a follow-up to Micha's first post in p.t.s-f
Newsgroups: povray.text.scene-files
Subject: Re: 3-sided bezier
Message-ID: <Xns### [at] povrayorg>
Date: 27 Aug 2002 16:28:33 -0400
Xref: news.povray.org povray.text.scene-files:3199
Ingo
