POV-Ray : Newsgroups : povray.advanced-users : 2 questions Server Time
21 Dec 2025 17:35:34 EST (-0500)
  2 questions (Message 1 to 8 of 8)
Subject: 2 questions
Date: 3 Mar 2000 07:08:13
Message: <38BFAAEE.4B962461@psu.edu>
howdy, I have two questions for you guys.
1) What is the best way to light a scene containing a lot of glass. ie:
drinking glasses with liquid etc. I have tried multiple light sources
(point lights and area lights) but just cant seem to get it right. The
scene is either too light or two dark and the glasses all have very dark
regions in them. Should I encase the whole thing in a box or sphere to
increase the amount of ambient light?
2) This is a silly question of sorts, must you put a semi-colon at the
end of a declare statment? I always forget to, especially in multi-line
declares, and everything works fine for me.
-paul
Subject: Re: 2 questions
Date: 3 Mar 2000 07:22:31
Message: <chrishuff_99-697792.07240703032000@news.povray.org>
In article <38BFAAEE.4B962461@psu.edu>, Paul Daniel Jones
It sounds like you don't have max_trace_level high enough. Check out
global settings and max_trace_level in the manual, it basically tells
POV how many levels it can go into the scene, too few will cause
disappearing reflections and dark areas. If this is the problem, it
won't disappear no matter how many light sources you use.
Try adding this to the beginning of the scene:
global_settings {
    max_trace_level 24// 7 is the default, this often needs to be
                      // increased in scenes with reflection or
                      // transparent objects
It is not required in the current version, but might be in a future
version. You had better get in the habit now, while the only problem it
causes is a warning.(if it happens in a loop, all those warnings can
also slow parsing down)
Chris Huff
e-mail: chr### [at] yahoocom
Date: 3 Mar 2000 07:26:08
Message: <38bfaf60@news.povray.org>
Paul Daniel Jones <pdj### [at] psuedu> wrote:
: the glasses all have very dark regions in them.
  Increase max_trace_level (and be prepared for a _long_ render).
Date: 3 Mar 2000 07:29:21
Message: <38BFAE02.7C91643E@pacbell.net>
As my learned colleagues have already mentioned the max trace level will
help here but what the glass object is refracting is also an important
element. The amount of ior specified will also contribute. Personally
I often add something outside the view of the camera to help give the
glass object(s) something else to refract besides the color black.
Date: 3 Mar 2000 08:16:03
Message: <38BF653F.C26D2213@psu.edu>
Thank you very much for all the suggestions. You know, I love Pov-ing (my
girl friend does not though "you spend too much time doing that
stuff!".......), but there are a lot of things I still don't know.... :-)
> -paul
Date: 3 Mar 2000 09:53:56
Message: <38bfd204$1@news.povray.org>
Only for numbers and vectors, if I remember correctly, and then you only
get a warning if you forget.  For now.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 3 Mar 2000 13:21:20
Message: <38C00316.134D2E7E@peak.edu.ee>
It _is_ required and can cause errors, although in most common cases it
doesn't. Macros can be picky about omitted semi-colons, and you can save
yourself a lot of headache by getting into the habit of using them.
Margus
Date: 3 Mar 2000 13:28:14
Message: <38C004B6.EFD15881@peak.edu.ee>
Note that besides the possible max_trace_level problem, dark areas can
be caused by total internal reflection, i.e. the inside of the glass can
reflect a dark part of the scene (such as a black background)
Total internal reflection is a component of refraction calculations, it
is independent of the 'reflection' keyword and currently cannot be
turned off (anyway, the glass would usually look unrealistic without it)
Margus
