POV-Ray : Newsgroups : povray.advanced-users : Aren't these perpendicular? Server Time
2 Nov 2024 09:19:52 EDT (-0400)
  Aren't these perpendicular? (Message 1 to 7 of 7)
Subject: Aren't these perpendicular?
Date: 19 Jan 2000 23:16:51
Message: <3886899D.DEF3CD7C@faricy.net>
camera { location <50,50,-50> look_at <20,0,0> up
<50-50*sqrt(2),sqrt((50*sqrt(2)+30)/2),-sqrt((50*sqrt(2)+30)/2)> }
Why does it complain?
Subject: Re: Aren't these perpendicular?
Date: 20 Jan 2000 00:23:09
Message: <38869bbd@news.povray.org>
David Fontaine wrote in message <3886899D.DEF3CD7C@faricy.net>...
Because the 'right' vector may not be perpendicular to the other two.  Try
adding this to your camera:
right
vcross(<50-50*sqrt(2),sqrt((50*sqrt(2)+30)/2),-sqrt((50*sqrt(2)+30)/2)>,(<50
,50,-50>-<20,0,0>))
You might need to multiply the vcross by -1 to get the correct coordinate
system (Left-handed or right-handed).
Mark
Date: 20 Jan 2000 03:03:23
Message: <3886c14b@news.povray.org>
You will save yourself a lot of trouble if you just rotate the camera.
Date: 20 Jan 2000 20:09:43
Message: <3887AF3A.C6F77C1A@faricy.net>
You can do that? I'll have to try it out, but the math is fairly simple so I
didn't mind doing it (except the part about it not working).
Date: 20 Jan 2000 20:10:00
Message: <3887AF4D.BB67D7EA@faricy.net>
Does it default to something?
Date: 21 Jan 2000 00:35:57
Message: <3887f03d@news.povray.org>
David Fontaine wrote in message <3887AF4D.BB67D7EA@faricy.net>...
Try
Yes, it defaults to <4/3,0,0>, but is modified when the look_at (but not the
'up') is changed so that it stays pointing in a direction perpendicular to
the direction the camera is pointing.
Mark
Date: 21 Jan 2000 04:07:32
Message: <388821d4@news.povray.org>
David Fontaine <dav### [at] faricynet> wrote:
:>   You will save yourself a lot of trouble if you just rotate the camera.
: You can do that?
  Yes. For example:
camera { location -z*10 look_at 0 angle 35 rotate x*45+y*30 }
: I'll have to try it out, but the math is fairly simple so I
: didn't mind doing it (except the part about it not working).
  Yes, the math is simple if you know it, but sometimes it's just easier to
rotate.
