POV-Ray : Newsgroups : povray.advanced-users : Is this a bug? Server Time
30 Sep 2024 18:09:13 EDT (-0400)
  Is this a bug? (Message 1 to 8 of 8)
Subject: Is this a bug?
Date: 3 Sep 1999 12:05:59
Message: <37cff1e7@news.povray.org>
Someone discovered this bug in povray.newusers. I'm confirming that it
really is a bug before posting a bug report.
  When rendering the following scene povray issues the warning "No pigment
type given" although there are no objects without pigment in the scene.
  If the 'material' statement is removed and 'Test' is used as 'texture'
instead, the warning disappears.
camera { location -z*5 look_at 0 }
light_source { <100,100,-100> 1 }
#declare Test=
  material
  { texture { pigment { rgb x } }
union
{ sphere { -x,2 material { Test } }
  sphere { x,2 material { Test } }
Subject: Re: Is this a bug?
Date: 3 Sep 1999 14:45:42
Message: <37D01826.2A7BE477@merlin.net.au>
> #declare Test=
>   material
> union
It does seem to be a bug.  The warning goes away if any type of pigment
is given to the union outside of the objects.
It works with material{Test} or with pigment{whatever}.
Cheers, PoD.
Date: 3 Sep 1999 16:11:52
Message: <37d02b88@news.povray.org>
Yes, it really is a bug.  I'm taking the liberty of posting the bug report;
hope that's okay.
>#declare Test=
>  material
>union
Here's the problem:  In parse.c, in the function Parse_Object_Mods, the part
that parses materials doesn't set the TEXTURED_OBJECT flag.  Here's something
that looks like a diff but isn't really one (because my line numbers would
be wrong anyway, since I look for these things in the superpatch code):
     CASE (MATERIAL_TOKEN)
       Local_Material.Texture  = Object->Texture;
       Local_Material.Interior = Object->Interior;
       Parse_Material(&Local_Material);
       Object->Texture  = Local_Material.Texture;
+      if ( Object->Texture ) {
+        Object->Type |= TEXTURED_OBJECT;
       Object->Interior = Local_Material.Interior;
     END_CASE
Date: 3 Sep 1999 16:26:10
Message: <37D02E8A.E3C566B8@pacbell.net>
  Something else I just noticed that is odd from the original posters code.
He has a pigment identified as - pigment { color <1,1,1> }
  I never realized you could validate a color like this without the use of
the RGB(FT) identifiers.
 pigment { color <1,1,1> } // is valid
 pigment {   rgb <1,1,1> } // also valid
 pigment {       <1,1,1> } // invalid and understandably so
The more I use this program the more loop holes I seem to find...
Ken Tyler
See my 850+ Povray and 3D Rendering and Raytracing Links at:
Date: 3 Sep 1999 16:29:02
Message: <37d02f8e@news.povray.org>
I noticed that yesterday when I was looking at the {checker Red White} bug.
See that posting for even more interesting loopholes, like "Red green 1"
as an obfuscated notation for yellow.
Date: 3 Sep 1999 16:41:39
Message: <37d03283@news.povray.org>
For some of us who actually like to write a lot more into the script
(albeit unneccessarily) this wouldn't change anything.  For Ken and
others this is obviously good news I'm sure  ; )
However.... if you aren't in a pigment pattern then 'rgb' is all you
need even if using a 4 or 5 place vector and it's 2 letters less than
'color'.
Ken <tyl### [at] pacbellnet> wrote in message
news:37D02E8A.E3C566B8@pacbell.net...
use of
> Ken Tyler
Date: 5 Sep 1999 01:03:02
Message: <37d1f986@news.povray.org>
Ron Parker wrote in message <37d02f8e@news.povray.org>...
it
code.
Obfusicated POV-Ray -- an interesting idea...:-)
Mark
Date: 8 Sep 1999 08:20:54
Message: <37d654a6@news.povray.org>
Ken wrote in message <37D02E8A.E3C566B8@pacbell.net>...
I noticed something like that the other day. I had three objects.
First one
 pigment {color Red}
Second one
pigment {color Blue}
third one
pigment {color Yellow}
Only got a parse error at the third one, which confused be until
I realised that the color keyword shouldn't have been there.
Gail
* gsh### [at] monotixcoza              * ERROR: COFFEE.COM not found  *
* http://www.rucus.ru.ac.za/~gail/ * Insert cup and press any key *
   My Software never has bugs, It just develops random features
