POV-Ray : Newsgroups : povray.advanced-users : Importing DXF, WMF etc : RE: Importing DXF, WMF etc Server Time
24 Oct 2026 06:36:52 EDT (-0400)
Date: 15 Mar 2003 15:29:38
Message: <3e738d32@news.povray.org>
CB <col### [at] nospamcouk> escribió en el mensaje de noticias
3e71d811$1@news.povray.org...
> Is it possible to "import" objects or shapes created in other graphics
> drawing programs such as DXF meshes, WMF etc.
> In particular I have a shape which I created in CorelDraw which I can
> obviously export in various formats, and I'd like to be able to use it in
> PovRAY in an extruded form.
> Is this possible in PovRAY, or by using a pre-processor?
You can use Wings 3D to import Adobe Illustrator files (.ai).
If you are using CorelDraw you can export your shape to
.ai format and open it in Wings 3D and extrude it there.
Later you can export the result to Povray as a mesh.
Wings 3D is available at:
http://www.wings3d.com/
> I'd also like to know if DXF meshes can imported into PovRAY.
As the others said, Crossroads 3D or 3Dwin are a good solution.
Bye
Txemi Jendrix
http://www.txemijendrix.com
