POV-Ray : Newsgroups : moray.win : Bug: Fog GUI Labels Server Time
17 Nov 2025 02:38:16 EST (-0500)
  Bug: Fog GUI Labels (Message 1 to 2 of 2)
Subject: Bug: Fog GUI Labels
Date: 24 Feb 2005 14:22:03
Message: <421e295b$1@news.povray.org>
I've been having a lot of problems with fog, and it looks to me as if the
settings between the GUI and the exported code have flipped the offset and
the altitude.
If I put in an offset of -100, and an altitude of 10, I get:
  fog_offset   -100.0
  fog_alt      10.0
That LOOKS correct on the face of it.  However, the POV Doc's says:
For ground fog, the height below which the fog has constant density is
specified by the fog_offset keyword.
So 'offset' is more like 'altitude'.
The POV Doc's say: The fog_alt keyword is used to specify the rate by which
the fog fades away.
So 'alt' isn't really an altitude, it's a rate of decay.
Maybe no one else has a problem with this but I really pounded my head
against the keyboard on this one.  I would recommend changing the GUI labels
somewhat to be more descriptive (given the same POV Ray keywords).
        == John ==
Subject: Re: Fog GUI Labels
Date: 27 Feb 2005 09:20:06
Message: <4221d716@news.povray.org>
"John D. Gwinner" <joh### [at] cornelledu> schreef in bericht
news:421e295b$1@news.povray.org...
> the altitude.
>   fog_offset   -100.0
>   fog_alt      10.0
which
> the fog fades away.
labels
Hi John,
<grin> glad (?) to see others have also confusion on this issue :-)
Fog_offset is indeed the altitude below which the fog is constant; and
altitude is indeed the rate of decay of the fog.... very confusing.
The problem is not with Moray, nor really with Pov, but with the terminology
indeed. I confess that I had also constantly problems with knowing exactly
what was going to happen. I solved it by making a little drawing for myself
explaining how things worked. I must say that since then the problem was
solved.
