POV-Ray : Newsgroups : moray.binaries : New Domenator plugin Server Time
23 Jun 2026 22:16:26 EDT (-0400)
  New Domenator plugin (Message 1 to 10 of 11)
Subject: New Domenator plugin
Date: 1 Sep 2004 13:30:13
Message: <41360725@news.povray.org>
Hello,
As john asked me for few improvements on Domenator, I worked on it and here
is where I am :
1) The degenerated triangles are removed
2) A new base is added
3) A new window is added
4) Five new slopes are added
5) A new parameter allows to have the meridians lines evenly spaced along
the slope (see sample TestNewDome Evenly.jpg)
6) A new parameter allows to shrink or to inflate the wires along the slope
(see samples TestNewDome alien Starfish.jpg and TestNewDome Shrink.jpg)
Before I release this new version I still have some work to do, so if you
have any suggestion for improvement of this plugin, this is the right place
and the right moment.
Philippe Gibone
Download 'TestNewDome Shrink.jpg' (16 KB) Download 'TestNewDome Evenly.jpg' (13 KB) Download 'TestNewDome alien Starfish.jpg' (12 KB)
Preview of image 'TestNewDome Shrink.jpg'
Preview of image 'TestNewDome Evenly.jpg'
Preview of image 'TestNewDome alien Starfish.jpg'
Subject: Re: New Domenator plugin
Date: 2 Sep 2004 03:39:44
Message: <4136ce40$1@news.povray.org>
Hey, looks great!
Arne
Philippe_Gibone schrieb:
> Hello,
> is where I am :
> Philippe Gibone
Date: 5 Sep 2004 03:25:36
Message: <413abf70$1@news.povray.org>
Philippe, your plugin is (and has been) an excellent addition to Moray. Last
year I made a scene using the plugin (for making roofs). I shall post it in
p.b.i. Hope you like it.
Date: 15 Sep 2004 02:11:20
Message: <4147dd08$1@news.povray.org>
Wow, looks nice.
My main suggestion is this:
1) I want to make the 'sides' of the panes of the dome have a 'thickness' so
that I can use them to make domed cities.  The wires/spheres work very well
for this, but there is no setting for the mesh that makes up the body of the
dome itself to have a thickness.
(See screenshots in 'Dome Plugin').
        == John ==
P.S.  Sorry for the late reply :(
Date: 15 Sep 2004 11:20:34
Message: <41485dc2$1@news.povray.org>
so
well
the
Hi John,
I'm afraid there is no way to give a thickness to a mesh ;-((.
The functions I use are parametric (and very complicated ones), no way to
spin them into an implicit function that can be used in a "thick"
isosurface.
There is a possibility to build the dome with elementary prisms, but, i'm
afraid it's the hell of a job...
If anybody can think of something else....
Philippe Gibone
Date: 16 Sep 2004 08:06:46
Message: <41498231.8010600@hotmail.com>
As a postprocessing step after generating the mesh:
Copy the mesh and offset all the points in the direction of the
normal. connect all the points at the egdes of the two meshes.
Will not work properly if the offset results in mesh intersections.
Or is that not the sort of answer you are looking for?
> so
> well
> the
> Hi John,
> isosurface.
> Philippe Gibone
Date: 16 Sep 2004 08:13:28
Message: <41498368@news.povray.org>
news:414### [at] hotmailcom...
This will not work, because the panes will not be thick, but only,
apparently thick. If you difference the dome with something else you'll see
the two meshes with vacuum in-between, but not a cut thick dome ;-(((
Thanks anyway for helping.
Philippe
Date: 16 Sep 2004 08:23:30
Message: <4149861D.5000507@hotmail.com>
If you connect the two meshes together at the edges it is just one mesh,
so that will work. NB don't forget to flip all the triangles
in one of the two, otherwise to normal (and thus the inside and outside)
is not defined consistently.
Date: 16 Sep 2004 09:37:16
Message: <4149970c@news.povray.org>
What happens if you make an intersection of the Dome with another object ?
see
Date: 16 Sep 2004 10:25:01
Message: <4149A297.4050100@hotmail.com>
I am not sure what you mean.
The result should be a normal, standard mesh.
But perhaps I am missing something.
If you have a small example I might give it a go
somewhere over the weekend.
(you can mail it to the hotmail address).
> see
