POV-Ray : Newsgroups : moray.binaries : City Plugin problem file Server Time
13 Jun 2026 08:31:47 EDT (-0400)
  City Plugin problem file (Message 1 to 5 of 5)
Subject: City Plugin problem file
Date: 21 Oct 1999 11:36:50
Message: <380EFB0C.F93D4481@cyberhighway.net>
Help!  i am truing to use the  City plugin but nothing is rendering!
see file in moray.binaries.   If you see what i am doing wrong PLEASE
tell me  so i won't make the same mistake twice......     BTW this was
written after 16 straight hours of working on it......
Download 'city2.mdl.dat' (3 KB)
Subject: Re: City Plugin problem file
Date: 21 Oct 1999 13:16:27
Message: <380f4a6b@news.povray.org>
Works fine for me. Did you put all of the include files in the proper
places? That may be your problem. Also, try reducing the magnitude of your
point light back to the default setting (1.0). It looks really washed out
the way it is.
Hope this helps at least a little!
Bill
Psychomek <psy### [at] cyberhighwaynet> wrote in message
news:380EFB0C.F93D4481@cyberhighway.net...
Date: 1 Nov 1999 13:53:06
Message: <381DE242.C44A20C1@totalise.co.uk>
Hi Psychomek,
I can't find anything wrong with it, but I noticed that this version of the file is
called city2.mdl. Did you call a previous version city.mdl? If you did you
may have overwriten the City.inc files, thus causing the scene to fail to render.
For this reason it is best to put the city.inc files in the Povray\include directory
not
Moray\povscn.
Does Pov output any messages in the messge window?
Keith
>    city2.mdl    Type: MorayW Document
(application/x-unknown-content-type-MorayWin.Document)
>             Encoding: base64
Date: 4 Nov 1999 08:31:16
Message: <38218AE1.33DD17AB@cyberhighway.net>
No messages....   and it wasn't over writing the city.inc file cause there was no
city.mdl.....
when i unzipped it i noticed the city.inc and acted accordingly...   but i found out
what was
wrong anyhow...  i didn't have the files in the right place.....
they must be in the same dir as the pov file or else nothing
Keith Hull wrote:
> Hi Psychomek,
not
> Moray\povscn.
> Regards,
> Keith
> >             Encoding: base64
Date: 8 Nov 1999 16:13:11
Message: <38273DAB.6C951069@totalise.co.uk>
Hmmm.... You should put them where Povray can find them, usually in Povray\include,
then all should be well!
Keith
city.mdl.....
what was
> Keith Hull wrote:
> > Hi Psychomek,
is
directory not
> > Moray\povscn.
> > Regards,
> > Keith
> > >             Encoding: base64
