POV-Ray : Newsgroups : moray.binaries : Please Help...Two Images are diffrernt Server Time
10 Jun 2026 14:57:17 EDT (-0400)
  Please Help...Two Images are diffrernt (Message 1 to 8 of 8)
Subject: Please Help...Two Images are diffrernt
Date: 7 Apr 1999 02:57:02
Message: <370af3ae.0@news.povray.org>
Hello,
    Attached are two versions of the same image. Both were designed in
Moray. In fact, they're both the same .mdl file. Banner1 was exported to
PovRay for rendering using the "Render>Export". Morays options were set
<Note-Had to convert it to .jpg to make it small enough to post>
    Banner2 was rendered by using "Render>Raytrace(F9)" It got written
as a .png like it was suppose to. But, now it looks semi
translucent(Notice the extra light near the bends) Why is this? and how
do I tell PovRay to render in .png when I use the Export option?
    The object is a Brezier sheet. Banner1 is the way it's suppose to
look. but, since I plan on using the finished image on the Web, I
definitely don't want a 2.25+mb Bit map file..:)
Thanks for your assistence
David
Download 'banner1.jpg' (18 KB) Download 'banner2.png' (22 KB)
Preview of image 'banner1.jpg'
Preview of image 'banner2.png'
Subject: Re: Please Help...Two Images are diffrernt
Date: 7 Apr 1999 03:00:46
Message: <370af48e.0@news.povray.org>
Hmm, Interesting.
    That was my first attempt to post an image to a NG.  I got to
remember to Scale large images down...:) And, the Banner2.png lost it's
black background?
David <dpo### [at] inreachcom> wrote in message
news:370af3ae.0@news.povray.org...
> Hello,
to
set
how
> David
Date: 7 Apr 1999 09:06:55
Message: <370B4A06.ED6A471E@mninter.net>
David wrote:
> Hello,
*SNIP*
Sorry, this has no bearing on your problem, but if it is meant for the web,
I'd suggest using a JPG...the compression will make a 900k bitmap into a
100k or so, with very good quality.
> David
Only I can prevent narcissism!
Date: 7 Apr 1999 11:50:31
Message: <370B7099.B514B221@aol.com>
I don't use Moray, just know about it some. Sounds like you might have
the alpha channel set, although I do see black backgrounds on both here.
The Export is meant to just output the files, Raytrace is simply
outputting the image and with Moray settings. Should be a
"Output_File_Type=N" in the INI used for renders; come to think of it I
don't recall Moray making INI files to accompany the pov and inc files,
just one for itself I think, though I could be wrong. If it doesn't
you'll have to edit POV-Rays povray.ini file (located in \renderer\
folder) to add that line.
Also, that banner being a bezier patch might be double-illuminating too.
You should say which versions of the programs you are using so people
know.
David wrote:
> Hmm, Interesting.
> black background?
> > Hello,
> to
> set
> how
> > David
Date: 7 Apr 1999 23:56:22
Message: <370c1ad6.0@news.povray.org>
Bob Hughes <inv### [at] aolcom> wrote in message
news:370B7099.B514B221@aol.com...
Any little bit helps..:)
I normaly just was the Export option. But, using Raytrace was the only
way I could get it to write in the format I wanted.
Should be a
I
files,
I'll look and see if  if such a line is there.
too.
> know.
Why would it be double illuminating?
I'm using Moray V3.1(4196) and Povray 3.1a
Thank
David
Date: 8 Apr 1999 00:00:27
Message: <370c1bcb.0@news.povray.org>
Thanks, I'm aware of this. But, Moray/Povray doesn't output to
JPEG(Altought, Povray itself might, I don't know it that well)
The original BMP image was 2.25mb in size. Whereas, the JPEG was only
17k..) Big difference
Thanks for your assistance
David
web,
a
Date: 8 Apr 1999 03:58:43
Message: <370C537F.9FD2B307@aol.com>
Actually I speak without thinking a lot. I don't really know if bezier
patches "double-illuminate" (triangle meshes do apparently) because I'm
not always up on that kind of stuff.
However, that said, POV version 3.1a wasn't "fixed" as far as this goes,
so maybe...?
Better someone else spoke up rather than me though.
> too.
> > know.
> Thank
> David
Date: 18 Apr 1999 09:01:29
Message: <3719C83D.E42D0915@pacbell.net>
> so maybe...?
  If it were in fact the double illuminate bug appearing it would
manifest itself in both versions of the image and not just one.
The bug is non discriminatory where image file formats are
concerned.
Ken Tyler
mailto://tylereng@pacbell.net
