POV-Ray : Newsgroups : povray.advanced-users : Calculating normals and perturbing them. Server Time
15 Dec 2025 06:11:49 EST (-0500)
  Calculating normals and perturbing them. (Message 1 to 5 of 5)
Subject: Calculating normals and perturbing them.
Date: 26 Nov 2025 09:55:00
Message: <web.6927144c88506bcb9839f6ab25979125@news.povray.org>
I've been digging down to the foundations of computing normals, and I was
re-reading the following threads with fresh eyes.
https://news.povray.org/povray.binaries.images/thread/%3C609265e2%40news.povray.org%3E/?mtop=434022
http://news.povray.org/povray.binaries.images/thread/%3C5ff4b8da%241%40news.povray.org%3E/
https://iquilezles.org/articles/normalsSDF/
(Original pouet.net link: https://www.pouet.net/topic.php?which=5604 )
This thread recently got updated due to my inquiries, with no explanations, thus
the pyramid vectors straight from POV-Ray's normals.cpp
https://rodolphe-vaillant.fr/entry/87/normal-to-an-implicit-surface
I was also trying to re-code an old scene where I was initially trying to
replicate source-code methods in SDL, and I believe I was trying to do what
Cousin Ricky was doing - which is trying to use a scalar value to create a
"normal".
A surface normal is, by definition, a vector perpendicular to the surface at
that point.   It's a vector, not a scalar, so using the scalar result from an
SDL function as a normal really doesn't make any sense.
I believe one would need to use a spline function, a pigment function, or some
other vector-valued function to properly use a function {} in a normal statement
to get meaningful if not proper results.
Perhaps what Richard is seeing is the result of vector promotion or some other
under-the-hood modification of the scalar function, and that' why the raytraced
result is wrong.
I myself am currently trying to unravel the requirements and limitations of
trying to create normals in sdf using the pyramid vector method.
All I can say is that there is no inherent bias introduced by the pyramid vector
method, since everything cancels out to give straightforward central differences
in any orientation.
- BE
Subject: Re: Calculating normals and perturbing them.
Date: 26 Nov 2025 15:50:54
Message: <6927682e$1@news.povray.org>
> "normal".
So far as I understand, the scalar is an offset from the surface, and as
such, a vector perpendicular to the unperturbed surface is implied.
POV-Ray then computes a normal vector by comparing adjacent
perturbations, "adjacent" being defined by the 'accuracy' attribute.
I haven't examined the source code, so I could be wrong, but I would
expect "adjacent" samples to be free from bias, at least from opposite
directions.
This actually sounds like an excellent way to *introduce* directional
bias if you're not careful with the function.  ISTR some of POV-Ray's
built-in normals already have that problem.
Date: 26 Nov 2025 18:15:00
Message: <web.6927891629c138871f9dae3025979125@news.povray.org>
I mean, that sounds great.
But as far as I am presently aware, POV-Ray enters the Perturb_Normal() function
in normal.cpp with no geometric information other than the "EPoint".
So in what direction do we offset from that point?  The normal?
I believe that the whole reason for using the pyramid vectors is to compute the
normal in the first place so that it can then be perturbed by a vector-valued
function of amplitude bump_size or scale <x, y, z>.
I could very well be missing some key point, which is why I've been digging into
this when I have the time / remember to.
It uses the pyramid vectors to define the sampling points offset from the EPoint
by a value "Delta" which Nathan Kopp hard-codes to 0.02.
> directions.
Yes, it's taken me some time, but I believe that the tetrahedral arrangement of
the sample points ensures exactly that, no matter the orientation.
But directional bias is exactly how we are creating the normal pattern to begin
with.  If we just multiplied all of the pyramid vectors by a scalar, they would
all cancel out.  Because there's no inherent directional bias.   In order to
"apply a normal" to a surface, we have to introduce some sort of _directional
bias_ in the form of a vector.
That vector comes from the normal pattern functions, and so I think that in
order to create a real and meaningful normal pattern like we think of them, it
needs to be a 3-dimensional vector.  Otherwise, I think that "1" gets
transformed to <1, 1, 1>, "-1" gets transformed to <-1, -1, -1>, etc.
I may or may not get the opportunity to try this, but it would be useful to plot
expected normal scalar values as an overlay, and also render the potential
vector-promoted scalar values to see if they give the same results.
Definitely a lot to be learned here, on several fronts.
- BW
Date: 26 Nov 2025 19:45:00
Message: <web.69279ed729c138871f9dae3025979125@news.povray.org>
Well I did.  And it was as (unnecessarily) annoying, confusing, frustrating, and
difficult as these things always are.
I'm very interested in what the/your expected result is.
(very cool version statement - you have a lot of clever little things in your
scenes)
#version max (3.5, min (3.8, version));
light_source { <(frame_number = 2? 1: -1), 1, -1.4> * 1000, rgb 1 }
camera
{ location -6 * z
   right x
   angle 30
#declare OriginalFunction =
function
{ max
 ( select (x - 1, 1, select (x - 2, 0, 1)),
   select (y - 1, 1, select (y - 2, 0, 1))
#declare Pattern = function {
 spline {
  0, <0, 0, 0>,
  1, <1, 1 ,1>
#declare VectorValues =
normal {
 average
 normal_map {
  [function { Pattern (OriginalFunction(x, y, z)).red}]
  [function { Pattern (OriginalFunction(x, y, z)).green}]
  [function { Pattern (OriginalFunction(x, y, z)).blue}]
#declare Function = 1;
#switch (Function)
 #case (0)
  box
  { 0, 3
     pigment { rgb <1, 0.5, 0.5> }
     normal
      function {OriginalFunction (x, y, z)}
       accuracy 0.1
     translate <-1.5, -1.5, 0>
 #break
 #case (1)
  box
  { 0, 3
     normal
      VectorValues
       accuracy 0.1
 #break
#declare Ext = 5;
#for (Y, -Ext, Ext)
 #for (X, -Ext, Ext)
  text { ttf "arial.ttf", str (OriginalFunction (X, Y, 0), 0, 0), 0.02, 0.0
translate <-0.25, -0.25, 0> scale 0.5 translate <X, Y, -0.01> pigment {rgb
z*0.5} no_shadow}
Download 'cousinricky_normals.png' (19 KB)
Preview of image 'cousinricky_normals.png'
Date: 1 Dec 2025 10:50:00
Message: <web.692db87829c1388798de4e8625979125@news.povray.org>
Desmos 3d Calculator
https://www.desmos.com/3d/m5lelysfl1
Use lines 19 & 20 to change Theta and Phi
- BW
