POV-Ray : Newsgroups : povray.animations : Post-frame: Execution of shellout bash prohibited Server Time
8 May 2024 12:32:24 EDT (-0400)
  Post-frame: Execution of shellout bash prohibited (Message 1 to 4 of 4)
Subject: Post-frame: Execution of shellout bash prohibited
Date: 31 Dec 2023 09:55:00
Message: <web.65917f58b3f06a406e558a71fde6c206@news.povray.org>
A large portion of my animation is static. To avoid generating the same image
repeatedly, I want to use a post-frame command. When the first frame of a static
interval is made, I want the post frame command to copy the generated image to a
/static subdirectory. For the remaining frames of the static interval, the
POVray code will produce a black frame, and then the post-frame command will
copy the previously generated static frame into the black frame.
Since the povray.ini file cannot be told which copy command to execute, I use
bash ./fix.sh
where fix.sh is a text file that was written to by the POVray code.
When I try this, I get the error
Execution of shellout 'bash' prohibited
My OS is Linux Mint and my POVray build 3.7.0.10 is an unofficial version
compiled by Andreas Beckmann.
Is there any way I can get my bash command to execute?
Should I contact Mr. Beckmann?
Thank you.
Subject: Re: Post-frame: Execution of shellout bash prohibited
Date: 31 Dec 2023 11:00:00
Message: <web.65918f00cb00d1b57f6d9cf76cde94f1@news.povray.org>
hi,
> bash ./fix.sh
BASH is my shell too, in the .ini file though I write, eg
  post_frame_command = sh postframe.sh
usually with one or more arguments.
that could be due to the system-wide (named "povray.conf") settings.
to test, try running 'sleep 10' as your post frame command.  that should tell
you which "situation" you're facing.
regards, jr.
Date: 31 Dec 2023 11:50:00
Message: <web.65919b38cb00d1b56e558a71fde6c206@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> > bash ./fix.sh
> regards, jr.
Thank you! I found and edited the povray.conf file and now bash is working.
I don't see a way to add SOLVED to the subject, sorry.
Date: 1 Jan 2024 06:25:00
Message: <web.6592a04acb00d1b57f6d9cf76cde94f1@news.povray.org>
hi,
yes, "just" newsgroups.  thanks for feeding back, enjoy "povving" :-).
regards, jr.
