POV-Ray : Newsgroups : povray.unix : mozilla help Server Time
29 Sep 2024 06:26:02 EDT (-0400)
  mozilla help (Message 1 to 5 of 5)
Subject: mozilla help
Date: 3 Feb 2002 18:34:03
Message: <qqhr5ucba5unbhtgt2j4pnq39b3u2cjmiv@4ax.com>
I can't get mozilla to run. I think I have everything I need, from
what I could gather from strace's output (more precisely, from this:
strace mozilla 2> err ; grep open err), but it keeps saying "error
while loading shared libraries: cannot open shared object file: cannot
load shared object file: No such file or directory." Any help?
Peter Popov ICQ : 15002700
Subject: Re: mozilla help
Date: 3 Feb 2002 19:14:49
Message: <slrna5rkjf.ncm.steve@zero-pps.localdomain>
Try running ldconfig, also see if the libraries that it's talking
about are in /etc/ld.so.config, and see if the directories of
those files are in your LD_LIBRARY_PATH, just type:
echo ${LD_LIBRARY_PATH}
And it'll tell you what it's got in it.
Chances are that the libraries are there, but they're not quite where
the program thinks they are.
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
Date: 3 Feb 2002 19:48:02
Message: <3c5dda42@news.povray.org>
Try "ldd mozilla" to see what libraries it needs. ldd will tell you which
of them can't be found.
  If that library *is* installed in your system, you'll need to either
copy/link it to some directory mentioned in your LD_LIBRARY_PATH or you
have to add that directory to it.
Date: 4 Feb 2002 08:41:55
Message: <3c5e8fa3$1@news.povray.org>
>   which
"mozilla" is typically a shell script wrapper.  Also, ldd doesn't search
your path, so you need to do something like ldd `which mozilla-bin`
Peter: what distribution are you running, and where did you get your
mozilla from?
-Mark Gordon
Date: 5 Feb 2002 11:57:00
Message: <sc306ucc465ab7huh6n8e7168c8hfhh9v2@4ax.com>
Gosh, why didn't I think of that! Thanks, Warp, I fixed it. I quite
like the browser already :)
The missing libraries were all GTK related... turns out I didn't have
GTK. I thought I did as I run GVim but obviously I must have built it
with the Motif GUI (and it looks like Motif, too) and not GTK. Anyway,
all is fine now. (P.S. Of course I only installed what I needed :) )
