POV-Ray : Newsgroups : povray.unix : Call me thick... Server Time
29 Sep 2024 06:22:33 EDT (-0400)
  Call me thick... (Message 1 to 10 of 12)
Subject: Call me thick...
Date: 7 Mar 2002 18:33:10
Message: <pan.2002.03.07.23.37.05.928708.10616@kitty5.com>
but exactly how do i install pov 3.5 beta on linux?
can some one provide me with a command for the instal thingy that will do
the magic, placing povray in the genrally accepted location (where ever
that may be)
oh, and how about command for a test render (in X)
Ta :)
PGP Public Key
Subject: Re: Call me thick...
Date: 7 Mar 2002 20:45:17
Message: <slrna8g5r4.btd.steve@zero-pps.localdomain>
> that may be)
> Ta :)
My prompt looks like this: [sjlen:sjlen]$
and consits of username:directory.
[sjlen:sjlen]$ tar -xzvf povlinux.tgz
      listing from the tar command appears here.
[sjlen:sjlen]$ cd povray35/
[sjlen:povray35]$ su
Password:                     ##### type root's password here.
[root@zero-pps povray35]# ./install
[root@zero-pps povray35]# exit
exit
[sjlen:povray35]$ cd         ##### takes you back home.
[sjlen:sjlen]$ cd pov   ##### directory where I know there are .pov files.
[sjlen:pov]$ povray -ipovtest.pov
And it goes and renders.  In X and in the console the comandline is the
same.
You could check out my PovMenu system for RXVTs if you like, but when
you're just starting out with it it's probably bes to mess about with
the command line.
You should have a .povrayrc file in your home directory.
Hope some of this helps.
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
Date: 8 Mar 2002 05:38:49
Message: <pan.2002.03.08.10.42.45.638824.12835@kitty5.com>
>> do the magic, placing povray in the genrally accepted location (where
>> ever that may be)
>> Ta :)
thats where i was going wrong!, i missed the ./ off!
great, it winges about not finding files in the library path, and ini
problems (ie lack of) but i cen get it going from here :)
btw, while i am on the subject, i remember povray 2.2 for dos having a
nice coulouful stats screen while rendering, nothing like that on the
linux version i assume?
PGP Public Key
Date: 8 Mar 2002 09:23:36
Message: <3c88c967@news.povray.org>
  Better:
[sjlen:pov]$ povray povtest.pov
  You can use filename completion that way.
Date: 8 Mar 2002 13:25:45
Message: <slrna8i0cr.f0v.steve@zero-pps.localdomain>
Don't know about this, I've never tried the histogram thingie whatever
that is. And the -h version doesn't seem to work in thes version, so not
as easy to find out about command line options quickly.
#local i=.1;#local I=(i/i)/i;#local l=(i+i)/i;#local ll=(I/i)/l;box{<-ll,
-((I/I)+l),-ll><ll,-l,ll>pigment{checker scale l}finish{ambient((I/l)/I)+
(l/I)}}sphere{<i-i,l-l,(I/l)>l/l pigment{rgb((I/l)/I)}finish{reflection((
I/l)/I)-(l/I)specular(I/l)/I}}light_source{<I-l,I+I,(I-l)/l>l/l} // Steve
Date: 9 Mar 2002 09:56:13
Message: <neoj8u4a24gr0kcdogkim4su7uu3njt0rs@4ax.com>
On Fri, 08 Mar 2002 10:42:45 +0000, "Rick [Kitty5]" <ric### [at] kitty5com>
DOS had a fixed-size window, and who knows how big your console will
be?
Peter Popov ICQ : 15002700
Date: 9 Mar 2002 19:01:35
Message: <pan.2002.03.10.00.05.29.557841.3152@kitty5.com>
> DOS had a fixed-size window, and who knows how big your console will be?
no it didnt :)
PGP Public Key
Date: 10 Mar 2002 06:15:46
Message: <2rfm8u415uh8n8i83sk531mq709nc6uvuh@4ax.com>
On Sun, 10 Mar 2002 00:05:29 +0000, "Rick [Kitty5]" <ric### [at] kitty5com>
>no it didnt :)
OK, a few fixed sizes then :) It's not as if you could drag the corner
of your SSH console window and make your screen 200x6 or something
like that.
Date: 10 Mar 2002 07:37:57
Message: <pan.2002.03.10.12.41.51.495375.16243@kitty5.com>
>>> be?
>>no it didnt :)
> of your SSH console window and make your screen 200x6 or something like
> that.
My xterms have a fixed width tho....
PGP Public Key
Date: 10 Mar 2002 09:12:08
Message: <3c8b69b8@news.povray.org>
  How is this possible? Every xterm I have seen has a completely free size.
