POV-Ray : Newsgroups : povray.unix : Announce: RendView-0.6.9 Server Time
29 Sep 2024 14:11:49 EDT (-0400)
  Announce: RendView-0.6.9 (Message 1 to 1 of 1)
Subject: Announce: RendView-0.6.9
Date: 17 Jul 2003 06:08:32
Message: <3f16759f@news.povray.org>
[Sorry for multi-posting with p.b.utilities -- just read about the
difference on http://news.povray.org/povray.announce.frequently-asked-
questions/16710/?tmax=100]
RendView is a utility to have films rendered using POVRay
and post-processed in a local distributed UNIX/Linux environment. Features
include rendering/filtering a sequence of frames (f000.pov,f001.pov...)
or a list of scene files and POVRay clock values, tuning on per-frame
basis, and resuming partly-rendered images, all either completely
locally or distributed in a local IP network.
RendView has been used by me to render films on a 20-node dual processor
Linux pool and it rocked. However, due to lack of time, I did not do
very much testing with version 0.6.9 -- everything should work but
e-mail me in case of trouble.
New features: (0.6.7 -> 0.6.9)
  - Checking mtime of additional files
  - LDR passwords from file
  - automatic compensation of different system times on client and server
  - use of a simple fit strategy for how to assign frames to clients
    when only a few frames are left
  - and support for use of a shared directory (NFS) between clients and
    server (normally RendView transferres files between client and server
    using a TCP connection)
Check the homepage for more information about the latter two points.
Bugfixes: Check out the homepage
Homepage:
 http://www.cip.physik.uni-muenchen.de/~wwieser/ani/rendview/
Demo/Examples:
http://www.cip.physik.uni-muenchen.de/~wwieser/ani/rendview/docu/examples.html
Have fun...
Wolfgang
Subject: Re: Announce: RendView-0.6.9
Date: 17 Jul 2003 06:14:13
Message: <igtchvs24jiq671vfkta1lt0mu8lep4d9o@4ax.com>
On Thu, 17 Jul 2003 12:07:33 +0200, Wolfgang Wieser <wwi### [at] gmxde> wrote:
You can always cancel post and repost it correct, thought useles when first
answer appear.
> and post-processed
What you mean as 'post-processed'. I searched your site carefully and found
only "glowfilter" mentioned in examples. I can find section about
post-processing in your site - any more details ?
ABX
Date: 17 Jul 2003 06:39:29
Message: <3f167ce0@news.povray.org>
> first answer appear.
Really? I don't know how to cancel a post. Could you enlighten me?
>> and post-processed
> found only "glowfilter" mentioned in examples. I can find section about
Well, you can use any filter which reads the image from stdin
and writes a processed image to stdout. Such "filtering" is what I
mean with "post-processing".
However, RendView does not provide any such filter by itself -- it just
provides a possibility to have the filtering done (just as it does
not provide a renderer -- you need to use POVRay).
Also the "glowfilter" does not exist. It's just there as an example
of what you could do (use e.g. "cjpeg" instead of "glowfilter").
The best "filter" is probably a custom shell script which does
what you want depending on the arguments you pass to it (which can
be tuned on a per-frame basis). [Note however the chapter about
shell scripts.] This enables you to use more than one filter for
a frame.
Wolfgang
Date: 17 Jul 2003 07:03:52
Message: <870dhvo7o2el1ua94g1lveoija7r6j60s6@4ax.com>
On Thu, 17 Jul 2003 12:38:29 +0200, Wolfgang Wieser <wwi### [at] gmxde> wrote:
http://knode.sourceforge.net/doc_en_0.3.2_online/more-knode-features.html#SUPERSEDE-AND-CANCEL
I see. I thought I could find some interesting algorithms to include in set of
macros prepared for MegaPOV 1.1 as for example in
http://news.povray.org/povray.binaries.animations/32438/
ABX
Date: 17 Jul 2003 16:37:25
Message: <3f170905@news.povray.org>
Thanks.
But I'm not sure if it works. I posted this message without this
note here and I can still see it in my reader...
Can you read it twice?
> set of macros prepared for MegaPOV 1.1 as for example in
Interesting stuff... hope it does not render too long.
The more "postprocessing" we can do with POVRay, the better.
Wolfgang
