POV-Ray : Newsgroups : povray.unix : povbench Server Time
29 Sep 2024 04:20:15 EDT (-0400)
  povbench (Message 1 to 10 of 23)
Subject: povbench
Date: 11 Jun 2002 07:25:11
Message: <3d05de17@news.povray.org>
Hello,
finally, I've found the time to compare the different compilations of
povray on a Pentium IV.  I used megapovplus and modified povbench.pov from
povray 3.5 beta to run on it.
Running time in seconds:
               P-IV   Athlon
gcc 2.95.3    13354    7035
gcc 3.0.1     11319    6555
gcc 3.1        8971    5901
icc 6         15907    5679
icc 6 IV      10589
"P-IV" is a Intel(R) Pentium(R) 4 CPU 1.60GHz
running SuSE Linux with kernel 2.4.16-4GB
"Athlon" is a AMD Athlon(TM) XP 1500+ (1343.051 MHz)
running SuSE Linux with kernel 2.4.10-4GB
Compiling options were:
gcc 2.95.3  -O3 -finline-functions -ffast-math -ansi -march=i686 -DCPU=686
gcc 3.0.1   -O3 -finline-functions -ffast-math -foptimize-sibling-calls
gcc 3.1     -O3 -finline-functions -ffast-math -foptimize-sibling-calls
icc 6       -O3 -tpp6  -xK -unroll -ip
icc 6 IV    -O3 -tpp7  -xW -unroll -ip
The last version is optimized for Pentium-IV. That's why the binary doesn't
run on the Athlon.
Best regards
Subject: Re: povbench
Date: 11 Jun 2002 15:13:58
Message: <3d064bf6$1@news.povray.org>
Thomas Willhalm wrote:
>                P-IV   Athlon
> gcc 3.1        8971    5901
I find gcc results "strange"... are you sure? It seems that gcc is getting
worse and worse!
Alessandro Coppo
a.coppo@<REMOVE_ME>iol.it
www.geocities.com/alexcoppo
Date: 11 Jun 2002 15:18:23
Message: <3D064CFF.5030504@free.fr>
>                P-IV   Athlon
> gcc 3.1        8971    5901
> icc 6         15907    5679
> icc 6 IV      10589
	Interesting. Looks like the last gcc is worth installing.
Well, I would have been glad to see gcc-3.0.4 intead of 3.0.1  :o)
Do you have any idea about the advantage of -foptimize-sibling-calls ?
And what is icc by the way ?
- Nicolas Calimet
Date: 11 Jun 2002 15:20:27
Message: <3D064D7B.10801@free.fr>
> worse and worse!
	Nope it's the opposite: "Running time in seconds" so the bench runs
faster with the last gcc.
Date: 11 Jun 2002 15:29:39
Message: <87lm9laa25.fsf@bach.composers>
Alessandro Coppo <a.c### [at] iolit> writes:
> >                P-IV   Athlon
> > gcc 3.1        8971    5901
> worse and worse!
It was rendering time in seconds - and you probably want shorter
rendering times, right? :-)
I find it amusing that Intel's compiler is beaten by GCC on P4, while
the reverse is true on Athlon. They should call it the "Intel C Compiler
for AMD processors"...
Ole Laursen
http://sunsite.dk/olau/
Date: 11 Jun 2002 15:44:58
Message: <3d065339@news.povray.org>
  Probably the Intel's own compiler, which should know how to best optimize
for Intel's processors.
Date: 11 Jun 2002 18:16:24
Message: <3d0676b8@news.povray.org>
In article <87l### [at] bachcomposers> , Ole Laursen
This is under Linux, of course.  It may just be a library issue that doesn't
exist under Windows.  gcc surely is not such a good compiler...
    Thorsten
Date: 11 Jun 2002 18:17:34
Message: <3d0676fe$1@news.povray.org>
In article <3d05de17@news.povray.org> , Thomas Willhalm
>                P-IV   Athlon
> gcc 3.1        8971    5901
> icc 6         15907    5679
> icc 6 IV      10589
What are the results of the Windows version on the same system?
    Thorsten
Date: 11 Jun 2002 18:47:02
Message: <3d067de6$1@news.povray.org>
How about adding any one of these: "-ipo", "-wp_ipo", "-prefetch", "-rcd"?
    Thorsten
Date: 12 Jun 2002 04:35:23
Message: <3d0707cb@news.povray.org>
>   optimize for Intel's processors.
Yes. It's the intel C++ for Linux. A non-commercial unsupported version is
available for linux free of charge at
http://www.intel.com/software/products/eval/
(You can get a 30-day evaluation version for Linux and Windows, too.)
