POV-Ray : Newsgroups : povray.unix : Linux Beta 9 now available Server Time
29 Sep 2024 06:23:58 EDT (-0400)
  Linux Beta 9 now available (Message 1 to 9 of 9)
Subject: Linux Beta 9 now available
Date: 9 Jan 2002 23:41:22
Message: <3c3d1b72$1@news.povray.org>
Just in time to expire in a few days, but I should have an update available
concurrent with other distros.
This is a fairly traditional povlinux.tgz, but with HTML docs in the
package.  The binary itself (just one, supports both X and SVGAlib,
uses whichever makes most sense) is statically linked so as to avoid
dependency issues (since you can't currently build against your own
installed libraries).  Built on Red Hat 7.2, in case it matters.
Future versions will involve a whole stack of RPM's and (at some
point) .deb packages, but I'm not going to bother with this one given that
it's due to expire so soon.  They'll be built with an prefix of /usr, but this
one is built with a prefix  of /usr/local, though, so as not to conflict with
anything you have in package management.   Keep a mind to your
$PATH if you end up with multiple versions installed in different prefixes
at some point.
Download from:
ftp://ftp.povray.org/pub/povray/Official/Linux/3.5beta/povlinux.tgz
It's a gzipped tarball.  Linux users (with GNU tar, one can assume) can
uncompress it with tar xvfz povlinux.tgz, then cd povray35 and run
./install as root.
There are some references to this being version 3.4.9, which is what
the later beta packages will be so as to allow for smooth upgrade to
3.5 once the beta period is over.
Please report any problems to the povray.beta-test group.
-Mark Gordon
Subject: Re: Linux Beta 9 now available
Date: 10 Jan 2002 00:59:28
Message: <1552881.MhQkTaH9nI@3-e.net>
> available concurrent with other distros.
<snip>
Thanks, I'm running it now via the latest KPOVModeler (0.1)
Seems to be working fine.
Subject: KPOVModeler (Was: Re: Linux Beta 9 now available)
Date: 10 Jan 2002 17:38:41
Message: <slrna3s5vd.7bn.Stephen.Oxley@midgard.its.monash.edu.au>
What did you do to get this to compile?  I grabbed the source tar-ball
(not the CVS stuff), and totally failed to get it compiled.
From what I recall, it was totally failing to use the correct Qt libraries
- it was wanting to use libqt instead of libqt-gl, and nothing I could
do would convince it otherwise... :-(  (And yes, I tried various options
to ./configure, even editting the ./configure script and all the
Makefiles failed to get it going.  Even typing in the final link command
(all 8 to 10 lines of it!) failed.)
Can you spare any pointers or clues?
Steve
ObRandomCynicalComment:
  Press every key to continue.
Stephen Oxley, Shared Systems Section,
Room G44, Building 28, Clayton Campus
Monash University, Victoria, Australia, 3800
Subject: Re: KPOVModeler (Was: Re: Linux Beta 9 now available)
Date: 10 Jan 2002 18:02:53
Message: <1301078.JJiE95MRjn@3-e.net>
No, I don't know what system you are using so I haven't a clue what you
need to do. It compiled fine on Mandrake 8.1 but you need to set $KDEDIR to
/usr for the install to work (I hand install my compile!)
I suggest you look at the mailing list for KPOVModeler.
Date: 10 Jan 2002 19:36:53
Message: <slrna3sct1.7bn.Stephen.Oxley@midgard.its.monash.edu.au>
Darn, sorry.
Debian Linux 2.3/3.0 (unstable / testing), kernel 2.4.12, KDE
2.2.<something>, gcc 2.95 (2.96? - not 3.0 anyway), latest version of Qt
libraries.
I shall take note of the $KDEDIR value, but from what I could see, the
configure script worked it all out for me.
I'll do that.  Thanks for the pointer.
Steve
  NT 5.0 is the last nail in the Unix coffin. Interestingly, Unix
  isn't in the coffin... It's wondering what the heck is sealing
  itself into a wooden box 6 feet underground...
Date: 10 Jan 2002 20:00:03
Message: <slrna3se8f.81n.Stephen.Oxley@midgard.its.monash.edu.au>
And since I tried to compile it, they've released a new version.  I
shall try my hand with that one and see what happens.
Steve
  NT tries to do almost everything UNIX does, but fails - miserably.
Date: 10 Jan 2002 22:58:48
Message: <1103366.uyWNOBFZWj@3-e.net>
OH I forgot to mention that, the new version came out a couple of days ago!
:o)
As for Debian, never used it, but the guys on the mailing list know their
stuff and can give you some pointers.
> Steve
Date: 11 Jan 2002 02:21:47
Message: <c84t3uscj59f3pop1spdhunduk360gt1lg@4ax.com>
On Wed, 09 Jan 2002 22:42:34 -0500, "Mark Gordon"
Thanks, Mark. I am sync-ing as I type :)
Peter Popov ICQ : 15002700
Date: 11 Jan 2002 14:21:53
Message: <slrna3ueb3.pkr.steve@zero-pps.localdomain>
My first tests showed it to be slower than 3.1g, but I havn't tested it
properly yet.  It complains a bit about skyvase too, it does render, but
from the messages I get I think it can only be fixed by updating my pov
.inc files.
  7:11pm  up 95 days, 10:59,  1 user,  load average: 1.02, 1.16, 1.13
