POV-Ray : Newsgroups : povray.unix : OT-ish question about the aero modeller Server Time
29 Sep 2024 12:17:11 EDT (-0400)
  OT-ish question about the aero modeller (Message 1 to 4 of 4)
Subject: OT-ish question about the aero modeller
Date: 30 Jun 1999 22:53:48
Message: <377ad83c@news.povray.org>
Hello, I just downloaded aero.  I am using Linux on a PC.  (Debian Linux, on
an AMD K6-2 333).  I tried getting the bianry version, and installing it.  I
stuck the executable in /usr/X11R6/bin, and IIRC I put the XAero file in
/root/GNUstep/Defaults.  I tried setting the XAPPLRESDIR thingie, but I must
have done it wrong, cuz it don't work.  I know, I shouldn't be running as
root, but it is a completely isolated box, and that is an argument for
another news server.
could somebody give me the correct command for Linux to set the XAPPL... so
I can use aero.
When that didn't work, I tried downloading the source, but that needed the
FWF, which I eventually found.  I can't compile the FWF stuff...  it says I
need imake, and some other thing.  grrr.   I just want to use aero!  Please
help!
On a side note -- the page hasn't been updated in quite a while, so I am
wondering how much work it will be to get it to run with the pov 3.0 I have
installed on my Linux partition?!  It talks about pov 2.0 in the docs.  Oh
well.
Thanks for any help!
Subject: Re: OT-ish question about the aero modeller
Date: 30 Jun 1999 23:04:03
Message: <377ADA61.56C9291@pacbell.net>
> well.
There are two download sites for Aero. One is a much newer version than the
other.
Old
http://www.informatik.uni-stuttgart.de/ipvr/bv/aero/aero.html
New
http://www.ee.uwa.edu.au/~braunl/aero/
Ken Tyler
mailto://tylereng@pacbell.net
Date: 1 Jul 1999 06:30:05
Message: <3779E522.BECB3CAB@my-dejanews.com>
> I can use aero.
The easiest thing is to put the Aero resources file where it belongs. cd
to the dir where you have aero and
cp aero/app-defaults/XAero /usr/lib/X11/app-defaults/
You can also manually merge the aero resources with
xrdb -merge aero/app-defaults/XAero
Compiling the XAero source and FWF is not that hard, imake (xmkmf) is
included with your gnu/debian system. Altough after compiling XAero, you
will need to setup it's resources and that's your original problem :).
Saludos!
Date: 2 Jul 1999 22:41:24
Message: <377d7854@news.povray.org>
Luis M. Ibarra wrote in message <3779E522.BECB3CAB@my-dejanews.com>...
so
>> I can use aero.
Hello, I just wanted to say that I did that, and finally figured out the
right command.  (silly me!!!)  I needed export
XAPPLRESDIR="/usr/lib/X11/app-defaults", while the docs had setenv...  Now,
I just need to find out how to get it to keep, so I don't have to type it in
every time I reboot.  (Where is that file....  I just need to spend a few
more minutes looking for it, I guess.)
Thanks for your help!
