POV-Ray : Newsgroups : povray.text.scene-files : [Minimum Volume] Bounding Ellipsoid via SVD : Re: [Minimum Volume] Bounding Ellipsoid via SVD Server Time
20 Jul 2026 21:55:20 EDT (-0400)
Date: 17 Nov 2019 21:45:01
Message: <web.5dd204daf7b9a3affeeb22ff0@news.povray.org>
hi,
> "jr" <cre### [at] gmailcom> wrote:
> > please post a data file.
> done.
cheers.
> >  when you say "400", are you trying to run a 400x400
> > matrix?  not sure but you *might* hit the limits -- the code's recursive, no?
> 400 x 3 matrix.   A "vector" data type that uses 400 povray vectors split up
> into x, y, and z values.
> So I just figured I'd read in the 400 first, size my array according to that,
> and then just pipe the whole file into the compiled SVD processor.
> Right now I just wanted to see if that worked, so I'm just gonna import the
> data, and then print it back out to show that that part works, then copy that
> working code into the SVD .cpp file.
> This is mid-hack, so it's uglier than usual    ;)
first glance -- I'd advise to supply both cols + rows as part of the matrix
data, rather than hardwiring the inner loop.
bedtime now, here.  hasta manana.
regards, jr.
