POV-Ray : Newsgroups : povray.text.scene-files : [Minimum Volume] Bounding Ellipsoid via SVD : Re: [Minimum Volume] Bounding Ellipsoid via SVD Server Time
20 Jul 2026 21:13:12 EDT (-0400)
Date: 17 Nov 2019 21:05:01
Message: <web.5dd1fc10f7b9a3affeeb22ff0@news.povray.org>
hi,
> So, since I don't code in c++, I'm kinda coding by imitation and trial and
> error.
> I get the current small bit of test code to compile, but when I run it with my
> dataset: "400" followed by 1200 numbers "value\n"
> #write (Output, NumPoints, "\n")
>  #write (Output, P[PonS].x, "\n")
>  #write (Output, P[PonS].y, "\n")
>  #write (Output, P[PonS].z, "\n")
> I get a segmentation fault.
please post a data file.  when you say "400", are you trying to run a 400x400
matrix?  not sure but you *might* hit the limits -- the code's recursive, no?
I'll monkey my version + try the data, in coming days.
regards, jr.
