hi,
Thomas de Groot <tho### [at] degroot org> wrote:
> Op 04/11/2019 om 09:09 schreef Thomas de Groot:
> > - the test is also useful with hyperboloid, superellipsoid, and
> > isosurface objects. Quartic and parametric objects do no comply,
> > probably they are not 'solid'? I did not test this thoroughly.
> The test (using version 2 of bounder.inc) for quartic objects is
> interesting. Using the Lemniscate object the BB seems to be infinite and
> the test is considered optimal. See image attached.
I think I will add, in the header/comments of the file, a list of "unsuitable
for use with this macro" shapes. what do you (and others) think? thanks.
regards, jr.
