Encore wrote:
> Ger <ger### [at] gmail com> wrote:
>> >> Here's the source.
>> >> Enjoy.
>> >> Ger
>> > Hello Ger,
>> > Thanks a lot for your help but then again this is rendering code. How
>> > to I generate an animation for this? Will I need an .ini file?
>> > Alex
>> There should be 2 files attached to the post, one is the cube source, the
>> other the ini file.
>> Ger
> nah unfortunately they both are the same file :P
> But I am now using:
> ; POV-Ray animation ini file
> Antialias=Off
> Antialias_Threshold=0.1
> Antialias_Depth=2
> Input_File_Name="transpAttempt2.pov"
> Initial_Frame=1
> Final_Frame=300
> Initial_Clock=0
> Final_Clock=3
> Cyclic_Animation=on
> Pause_when_Done=off
> in an .ini file I made at I'm computing the bmp files at the moment. If
> you want you can just verify I'm using the right code in my ini file. But
> so far the result seems to be fine ;)
I just checked and there was a second file attached called "cube.ini"
Running that will create a 720 frame animation. Btw, clock is not used, just
frame_number count.
Ger
