POV-Ray : Newsgroups : povray.pov4.discussion.general : Ideas. Updated f_wood(). povr branch. Server Time
12 Nov 2025 05:52:46 EST (-0500)
  Ideas. Updated f_wood(). povr branch. (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Ideas. Updated f_wood(). povr branch.
Date: 13 Sep 2021 19:25:00
Message: <web.613fdcdceea58d851f9dae3025979125@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> One of the distribution types recently added to f_distribtion() was a
> normal/gaussian. With this in hand, I took another run at an f_wood()
> supporting more realistic growth rings. I left all turbulence and
> displacement to outside actors.
This is very cool.   I experimented a bit with the marble pattern to try to get
a more irregular spacing of the veins and a variation in the width.  I'll have
to get back to that once things IRL settle down a bit.
Is it possible to implement this as a function in plain-vanilla SDL, or does it
require some "special sauce"?
Regardless, this is looking great as the basis for some excellent wood patterns.
 Looking forward to seeing this implemented with some black hole warps for the
knots, and a good color map and finish.   :)
Date: 14 Sep 2021 09:37:00
Message: <6140a57c$1@news.povray.org>
On 9/13/21 11:47 AM, Alain Martel wrote:
> Very interesting. Mostly useful for wooden objects that are viewed from
> a relatively short distance.
Thanks. Mostly, Yes. :-)
> Is there any way to have undisturbed rings in the centre with the
> disturbance increasing as you get farther ?
First, to be clear, the turbulence in the previously posted image was
accomplished with two 'external' to f_wood() turbulence warps. One for
fuzz in the rings and another for the log level. The f_wood() function
doesn't have any inbuilt turbulence - unlike the traditional wood pattern.
In povr certainly a fade is possible, as the Turbulence(1) and vector
turbulence (DTurbulence) functionality of POV-Ray is brought out as
inbuilt functions.
If not using that sort of functionality... I think one could probably do
something like an inward black hole warp(2), apply turbulence, then an
outward black hole warp. Similar to scaling patterns up (or down) prior
to applying turbulence and then reversing it.
While, the fade used is the opposite you asked about, attached is a test
isosurface image based upon f_wood() where I'm using the ring count
value to fade the rings to nothing in height while moving out from the
center.
FWIW, the, povr only, core SDL for the isosurface is:
#declare Fn00 = function (x,y,z) {
      f_wood(0,f_hypot(x,z),Core,Width,Rings,Seed,Mean,Sigma)
#declare Fn01 = function (v) {
      f_distribution(7,// A triangle distribution. Wikipedia version.
          f_dec2x_f32(v,0),
          A,B,C,ReturnMode,nullArg
      )* ((f_dec2x_f32(v,1)*-0.0035)+0.059) // The fade to nothing.
#declare Iso99 = isosurface {
      function { abs(y)-Fn01(Fn00(x,y,z)) }
Bill P.
(1) - The povr branch has fixed the forever standing Turbulence()
octaves distribution mean drift issue.
(2) - The povr branch has a black hole type 1 without the clamping
and/or reaching outside the black hole radius issues of POV-Ray's
black_hole. The povr type 1 forms would likely be needed for other than
linear fading / strength 1.
Download 'iso00_f_wood.jpg' (286 KB)
Preview of image 'iso00_f_wood.jpg'
Date: 14 Sep 2021 09:40:58
Message: <6140a66a$1@news.povray.org>
Thanks. Though called f_wood() it can be used with any gradient and so a
marble if you want.
As you probably know, the marble pattern is just a gradient in x where
the x position is jostled about by values from calls to Turbulence()(1)
(1) - Which has the distribution drift issue, if not using povr or other
branches where this is fixed.
:-) It needs to be inbuilt is the practical answer.
Could you do it in SDL for perhaps patterns only or ,perhaps, as a way
to pre-bake image maps for later use? Likely yes - but I've not done it.
The whole approach is more expensive than today's wood - especially
where the random values for the offsets fit a normal distribution. I
wanted to be able to use it on the fly and with isosurfaces - and for
that use - inbuilt is the only practical approach I think.
Bill P.
Date: 19 Sep 2021 04:25:00
Message: <web.6146f33feea58d855e0fed26cde94f1@news.povray.org>
hi,
> Roughly a year ago I re-worked the wood pattern and implemented an
> inbuilt function called f_wood() ...
> The documentation text from functions.inc: ...
> Though aimed at creating wood patterns, the function can be used with
> any gradient of values.
> Eight parameters required:
thinking aloud about the simulation, and not having used 'f_wood()' yet, as user
I think I'd like one simple (wrapper) function/macro where, ideally, I'd only
provide an "age" (ie #rings) and some average "annual" growth value to obtain a
pattern, and maybe a rand seed.  (I guess all eight parameters will be needed
when "tuning" some aspect(s) of the render)
unrelated, but I've only found out about two _exciting_ Tcl extensions; thinking
that when 'povr'/POV-Ray compiles, the "library" of backend stuff which is
linked late in the process, I'm fairly certain, could be (mis-)used ;-) with
either of these:
<https://wiki.tcl-lang.org/page/Ffidl>
<https://cffi.magicsplat.com/>
regards, jr.
Date: 19 Sep 2021 06:29:58
Message: <61471126$1@news.povray.org>
FYI - I've not published a povr version with f_wood().
Yes, a simpler interface would likely be the more common use case in
practice. With many of new inbuilt functions, I'm trying out and tuning
ideas. I want knobs and switches and expect further change
In fact With f_wood been thinking about additional return value pairs...
Internally, we are always tracking a previous positional sum for ring
count and the the next sum - so we can do a linear interpolation at the
value between the two value 'positions.'
My thinking is we can probably create some interesting isosurface
ladder/net/web like structures by using the leg positions of the ladder
as seeds and, local to the value, four corner positions. Maybe connect
up TOK's point to point linear sweeps on the fly.
> unrelated, but I've only found out about two_exciting_  Tcl extensions; thinking
> linked late in the process, I'm fairly certain, could be (mis-)used;-)  with
> either of these:
Thanks for the pointers. The first rings no bells, but I see from my
notes I've stumbled across the second site at some point.
I played some - looks like now, way back in 2019 :-| - with:
https://github.com/flightaware/cpptcl
which is based on a much earlier tcl function wrapper package that's
15-20 years older IIRC. There is too, of course, swig.
With tcl wrappers of C++, I always seem to get as far as a few examples,
but never much more before I drop the effort for other - less painful -
play. Someday...
On the practical side, I find I often drop back to to extracting enough
of the POV-Ray header structure to compile tiny c++ programs when first
trying bits of code. The compile / link loop is then really quick even
if I happen to be playing also with the headers. I've got an older two
core i3. Even with 'make -j4', changed header compiles take a while.
Bill P.
Date: 20 Sep 2021 09:45:00
Message: <web.61488f63eea58d855e0fed26cde94f1@news.povray.org>
hi,
when will you publish an updated version?  (will '-into' feature?  :-))
regards, jr.
Date: 21 Sep 2021 11:44:11
Message: <6149fdcb$1@news.povray.org>
On 9/20/21 9:40 AM, jr wrote:
> hi,
Suppose the answer to that second question, depends some on the answer
to the first. My best guess is '-into' won't be in the next one, if
another tarball gets publish relatively soon.
I've been hung up for a while on pushing certain, relatively broad,
changes I've been playing with over the past few months into the media
block. How, when - and whether I should go after other media changes
ahead of next publishing a tar ball.
Bill P.
Date: 26 Sep 2021 10:21:52
Message: <61508200$1@news.povray.org>
On 9/12/21 3:42 PM, William F Pokorny wrote:
>... I took another run at an f_wood() ...
Attached is an image where I'm starting to play more with the idea of
the updated f_wood creating patterns/structures not related to tree rings.
I've added two additional return modes, including the sumPrev, sum pair
one mentioned briefly elsewhere. However, this isosurface is just five
'z' cylinders and f_wood() applied in four 'z' columns between the
cylinders so it's not using the two new return modes.
Bill P.
Download 'f_wood_iso3.jpg' (153 KB)
Preview of image 'f_wood_iso3.jpg'
Date: 27 Sep 2021 09:47:54
Message: <6151cb8a$1@news.povray.org>
Attached another test image making use of f_wood()'s new sumPrev, sum
pair value return mode; coupled with Tor Olav Kristensen's linear sweep
trick coded up as the inbuilt f_labseep() function.
Bill P.
Download 'f_wood_iso04.jpg' (190 KB)
Preview of image 'f_wood_iso04.jpg'
Date: 3 Oct 2021 07:59:01
Message: <61599b05@news.povray.org>
On 9/27/21 9:47 AM, William F Pokorny wrote:
> sumPrev, sum pair
Another test image attached for f_wood() and as yet to be mentioned,
povr branch, finish block changes. Again using the sumPrev, sum pair
return - though differently - along with pattern turbulence (via
raw_wave) and f_eblob() for the blobbing.
Bill P.
Download 'f_wood_iso05.jpg' (448 KB)
Preview of image 'f_wood_iso05.jpg'
