POV-Ray : Newsgroups : povray.pov4.discussion.general : Docs and source code for various objects : Re: Docs and source code for various objects Server Time
17 May 2026 17:41:17 EDT (-0400)
Date: 3 Sep 2025 04:00:00
Message: <web.68b7f44b1cfdbd1917bac71e8ffb8ce3@news.povray.org>
> What do you all think?  Discuss.
Yes.
But, for all objects. It means we'd need a whole mesh library (openMesh etc.?)
to build on.
quite a bit of "all" objects can be represented as parametric.
sphere(
  0, 1
  resolution = <60, 30>
resolution triggers the system to create the parametric sphere, instead of the
solid.
tracing parametrics "always" requires some form of iteration like Newton-Raphson
/ iterative root-finding, subdivision / bounding volume hierarchy, Bezier
clipping etc.
One can use a "coarse" mesh as starting point and then do subdivision to
subpixel level, using the parametric eq set.
A side effect that I would welcome, if we can generate internal mesh of objects,
global meshify setting, we can do openGL pre-views.
An other side effect, subdivision modelling, though purely by script it's not
fun.
If I could write POVRAY5, i'd look into language and parsers in such a way that
it can spit out multiple things to serve multiple rendering back ends.
ingo
