POV-Ray : Newsgroups : povray.off-topic : C++ question Server Time
29 Sep 2024 15:26:20 EDT (-0400)
  C++ question (Message 1 to 7 of 7)
Subject: C++ question
Date: 8 Apr 2009 16:15:57
Message: <49dd05fd$1@news.povray.org>
How is it possible to invoke a virtual method that wasn't defined?  I.e., I
have a superclass that declares
   void abc(int) = 0;
What's happening that I can instantiate a child of that class without that
method defined, and then try to invoke the method? As far as I understand,
the type system should be preventing that, shouldn't it?
   There's no CD like OCD, there's no CD I knoooow!
Subject: Re: C++ question
Date: 8 Apr 2009 16:39:03
Message: <49dd0b67@news.povray.org>
>    void abc(int) = 0;
  If your compiler allows you to instantiate a class with pure virtual
functions, then your compiler is horribly buggy. Normally you should get
a compilation error along the lines of:
test.cc: In function 'int main()':
test.cc:13: error: cannot declare variable 'b' to be of abstract type 'B'
test.cc:8: note:   because the following virtual functions are pure within 'B':
test.cc:4: note:        virtual void A::abc(int)
  I guess that you are not really instantiating an abstract class, or either
you are doing something really weird which somehow is able to bypass the
compiler checks (in which case you get UB, of course).
Date: 8 Apr 2009 17:21:11
Message: <49dd1547$1@news.povray.org>
I don't know. I've seen it happen at runtime with "trying to invoke pure
virtual function" on Windows, and now I'm getting some of the same sorts of
messages from a Linux program (from a place where you're supposed to fill in
as you port it, so not entirely unexpected).
If you had class Beta as a concrete child of abstract class Alpha, and you
assigned a Beta to the Alpha (as in slicing it), the compiler would still
complain when you tried to invoke the undefined function in Alpha, wouldn't it?
Date: 8 Apr 2009 17:22:48
Message: <49dd15a8$1@news.povray.org>
Darren New wrote:
> you assigned a Beta to the Alpha (as in slicing it),
Oh, I see that you probably shouldn't be able to do this.
OK, as I get my brain wound up to deal with this more, I'll see if I can
figure out what's going on and follow up. Thanks!
Date: 9 Apr 2009 03:00:30
Message: <49dd9d0e@news.povray.org>
  That runtime error can happen when you call a pure virtual function from
the base class constructor (even if the object being instantiated is not
abstract). In other words:
class Base
 public:
    virtual void function() = 0;
    Base() { function(); }
  I'm not exactly sure how standard that behavior is, though. At least in
a current version of gcc you get both a warning and a linker error in this
situation if Base::function() has no implementation. However, I do remember
that in older versions of gcc it would compile and you would then get the
runtime error.
  (If the pure virtual function has an implementation in Base, what will
end happening is that this Base implementation gets called, rather than
the implementation in the derived class. Hence the warning.)
Date: 9 Apr 2009 04:35:12
Message: <49ddb340$1@news.povray.org>
> of messages from a Linux program (from a place where you're supposed to
> fill in as you port it, so not entirely unexpected).
Some of the PCs at work have some software that frequently spews out
that error message.
Unfortunately, several users think that what the message is saying is
"your computer doesn't have enough virtual memory", so they want me to
add more RAM to the PC. (Yes, I realise that's completely illogical. But
they seem pretty convinced about it, and won't accept my word that it's
nothing to do with memory. But hey, I'm only a qualified computer expert...)
Even more unfortunately, the makers of the software have released an
update which completely fixes this issue - but I'm not allowed to
install it.
Date: 9 Apr 2009 12:24:38
Message: <49de2146@news.povray.org>
> abstract).
Yeah, but that would happen even if the child object implemented the
function, yes?  In other words, this wouldn't be a bug of "you didn't
implement the child correctly", but rather a bug that would persist even
after the child object was correct?
Anyway, I'll be delving into this part of it pretty soon. Basically, as soon
as I've groped thru the hardware docs to see how I have to port the stuff.
I'll let youknow if I figure out what C++ is triggering this and how it
manages to compile.
(I do get some compile-time warnings, but they're mostly things like unused
member variables and switch statements that don't cover the entire
enumeration and such. Nothing at link time and nothing about abstract classes.)
