POV-Ray : Newsgroups : povray.off-topic : Practical Stargate kawoosh effect ideas : Re: Practical Stargate kawoosh effect ideas Server Time
15 May 2026 09:43:38 EDT (-0400)
Date: 11 Feb 2026 00:00:00
Message: <web.698c0c9c214fceddcfa89c9ea1376c@news.povray.org>
> "Nekar Xenos" <nomail@nomail> wrote:
> > The reason I posted this in off-topic was a thought experiment on what would be
> > the easiest way to use the above method to make it for a man-cave? Instead of
> > the periscope which is too small, put a 45 degree mirror behind your stargate
> > model and a clear plastic tub of water above it. Then use a compressor to blow
> > air in.
> OOOOoooooh.
> Constructing one IRL!
> Maybe you could make it small and magnify it, and then just use a pellet gun or
> a paintball marker for your air cannon.
> Perhaps even shoot the air through a small hole in a mirror to hide the
> mechanism.
> You could even use a webcam or something so that you could composite the
> stargate ring and the kawoosh somehow.
> - BE
 Yes, a magnifying mirror might work and maybe even help to bring the image more
foreward. Maybe I should try recreating it in Pov-Ray with photons.
-Nekar Xenos-
