POV-Ray : Newsgroups : povray.off-topic : Practical Stargate kawoosh effect ideas : Re: Practical Stargate kawoosh effect ideas Server Time
15 May 2026 10:30:56 EDT (-0400)
Date: 10 Feb 2026 07:05:00
Message: <web.698b1ea2214fced1f9dae3025979125@news.povray.org>
"Nekar Xenos" <nomail@nomail> wrote:
> The reason I posted this in off-topic was a thought experiment on what would be
> the easiest way to use the above method to make it for a man-cave? Instead of
> the periscope which is too small, put a 45 degree mirror behind your stargate
> model and a clear plastic tub of water above it. Then use a compressor to blow
> air in.
OOOOoooooh.
Constructing one IRL!
Maybe you could make it small and magnify it, and then just use a pellet gun or
a paintball marker for your air cannon.
Perhaps even shoot the air through a small hole in a mirror to hide the
mechanism.
You could even use a webcam or something so that you could composite the
stargate ring and the kawoosh somehow.
- BE
