POV-Ray : Newsgroups : povray.off-topic : Practical Stargate kawoosh effect ideas : Re: Practical Stargate kawoosh effect ideas Server Time
18 May 2026 02:19:07 EDT (-0400)
Date: 9 Feb 2026 12:20:00
Message: <web.698a1658214fced71bdebb325979125@news.povray.org>
"Nekar Xenos" <nomail@nomail> wrote:
> Today I went down the rabbit hole of Is It Possible To Recreate The Stargate
> Kawoosh theoretically as a practical effect? What I thought of first was take a
> periscope, remove the top part with the top mirror/prism and fill it with water.
> The viewer would now see water ripples on a vertical surface. Put a Stargate
> prop around the viewer and you're good to go. But obviously this will be too
> deep in and not be as close to the surface of the Stargate as it should be. Then
> I started thinking about the almost holographic effect of parabolic mirrors
> -that put my brain in an infinite fractal loop :-S
> Anyone have any ideas? :)
> -Nekar Xenos-
Hi Nekar,
Welcome back to the forums!  :)
like this? :
https://www.youtube.com/watch?v=Mi_xG8XovrE
I'm assuming that it's the big bubble effect of the unstable vortex that you're
trying to do?
Perhaps an isosurface with bubble paths mapped out in randomized sine-wave
spline paths?  That way the bubbles get subtracted from the liquid isosurface,
and whoosh outwards until a max at pi/2 and return to the glyph ring at pi?
Randomizing the path radially would give a fill-in over the whole surface of the
"water".
Of course you could do it with spheres and CSG as well.
We recently partially reworked a bubbles macro, and I did a physically correct
falling raindrop that you could use for bubble shapes as well.
I'd say that you'd want that extended "blooping" of a forcibly extruded air
bubble in water, though.
Maybe model that like the gravitational breakup of a falling stream of water.
- BE
