POV-Ray : Newsgroups : povray.off-topic : Still stumped by git branches : Re: Still stumped by git branches Server Time
13 Mar 2026 00:38:19 EDT (-0400)
Date: 13 Jan 2026 17:30:00
Message: <web.6966c75b37791759d57db8d19fe599e6@news.povray.org>
> I'm trying to learn branches in git, and one bit of advice I've heard,
> from the one video that's been most helpful to me, is that "merging
> locally isn't normally done; instead, changes are pushed and a pull
> request is made."  So I did that, and now my GitHub repo is up-to-date.
> GitHub also assured me that I could delete the branch, so I did that.
> But now, I've still got 2 local branches, and my local main[*] does not
> have the changes from the branch.  How do I update the local main if I'm
> not supposed to merge locally?
> I have both branches backed up locally, because frankly I don't know
> what I'm doing, and I've corrupted repos before and had to git init or
> git clone from scratch.  It's a hassle maintaining both git and manual
> systems in parallel, but at least I know I won't lose everything on my
> next git stumble.
> I've been using git for 4 years now, in part on the promise that it will
> make my life easier.  How can that happen when, after 4 years, this
> software is still utter black magic to me?
> [*]"master" using the old terminology.
If you aren't merging into a shared branch (i.e., if you're the only one working
on a project and you aren't updating two branches at once), I wouldn't give it a
second thought. The main idea is to avoid merge commits (which you can easily
end up with anyway if you accept a pr), but you won't have merge commits as a
single user if you
- git checkout some-branch (or) git checkout -b some-new-branch
- make come commits, decide you want to keep them
- git checkout main
- git merge some-branch
The only thing branching is giving you here is a "save point" in case you want
to discard an entire feature. Git, like many things, is as hard as you want to
make it.
