POV-Ray : Newsgroups : povray.object-collection : New (Experimental) Index Page : Re: New (Experimental) Index Page Server Time
15 May 2026 21:46:30 EDT (-0400)
Date: 22 Jun 2008 13:05:00
Message: <web.485e85a8133a8f9123ce54f40@news.povray.org>
"Chris B" <nom### [at] nomailcom> wrote:
> It should be possible now because it's a multi-select list. When you're
> submitting an object you should be able to use Ctl-Click in the browser to
> select multiple categories and sub-categories. Though the mechanism for
> doing a multi-select may vary between browsers and operating systems.
Thanks, I didn't notice that.
> This is a little more problematic. Certain functions of this sort can be
> done by an administrator but it needs a bit of consistent judgement to make
> sure that significant changes aren't made without changing the version
> number, otherwise people wouldn't be able to tell that an object had changed
> since they downloaded it.
Well, a step in this direction would be to only require a version number change
if any new files are uploaded. Of course, this would as a result be triggered
any time *any* file is uploaded, regardless if the actual code hase changed.
However, despite this quirk it would still be an improvement.
Thanks for your reply.
-Mike
