POV-Ray : Newsgroups : povray.news-submissions : SMPOV 3.60 with amazing new features released Server Time
20 Apr 2024 01:31:34 EDT (-0400)
  SMPOV 3.60 with amazing new features released (Message 1 to 10 of 12)
Subject: SMPOV 3.60 with amazing new features released
Date: 3 Jan 2004 14:34:33
Message: <3ff71949$1@news.povray.org>
What is SMPOV?
SMPOV is a System that splits renderjobs into smaller parts which can be
rendered at the same time by multiple CPU's local (SMP) or distributed in a
network.
Actual state of SMPOV:
The POV-Ray Community is quite busy so 4711 SMPOV downloads have been
counted from all over the world.
What is NEW in 3.60?
 The amazing news are:
1. Support for Resolutions up to 12200x12200 at no extra cost.
2. The readme file describes 3 new network-rendering-topologies, for
example:
"Cross-Rendering" - You can share the COM-Folder with friends, then everyone
can use everyones machine for POV-Ray rendering (with tiling - or without!).
Two examples:
"Shared Render-Pool" - you can share a "pool of Render-PC's" with other
POV-Ray-Users.
"VPN-Internet Rendering" - you can use SMPOV via the Internet therefore you
need to use a VPN for safety reasons. New is that you can share the
rendering resources over the Internet with others.
3. Speed of the RenderAgents and the distribution-process has been
increased.
4. Still there is NO Spyware in SMPOV and it does NOT connect to the
Internet other then through a VPN.
5. Includes a "Moray-Message Remover" WinRobot. If you use Moray you may get
a popup-Message when SMPOV starts multiple Instances of POV-Ray.
6. There are a lot of improvements in details fixing small weaknesses of the
past, which could make things not work in rare cases. I wont tell them all
here. Try it...
7. Not changed: Full support for POV Ray 3.5 as well as Mega-POV 1.0
Link: http://www.it-berater.org/smpov.htm
--Theo Gottwald
Distributed Network-Rendering or Local SMP-Rendering. With SMPOV and
POV-Ray 3.5. * Download free at: http://www.it-berater.org/smpov.htm
Subject: Re: SMPOV 3.60 with amazing new features released
Date: 3 Jan 2004 18:41:08
Message: <3ff75314@news.povray.org>
  Why such a low limitation? Some technical reason for that?
  I don't understand why this has to be explicitly said. This should be
taken for granted (most importantly because I'm sure that distributing
an adware version of POV-Ray would be outrageously against povlegal).
Date: 4 Jan 2004 03:07:48
Message: <3ff7c9d4@news.povray.org>
Hi Warp,
Just that I did not test higher Resolutions on my 1 GHz machine. If you need
more, just ask me
then you get a "eat on your own risk cake" for testing. It was really just
that I thought noone
would need more. For what do you need more? Theoretically I would say that
there is only a technical limitation in PicPender-2 for the output file to
be smaller then 2 GB :-) because thats the stringsize-limit.
This has to be tested if there is interest for that ...
Since last version it has some "hardcoded advertisment" for my brothers
diving base
in Thailand. Besides that you are right, I would NEVER produce anything that
contains
Spyware (so long i don't get an contract from NSA for that :-))))). However
I really wanted to say that explicitly so everyone can be shure about that.
Also the fact that you know explicitly that SMPOV will NOT connect to the
internet
under no circumstances is something that is worth to be told.
For me, if I have such an statement, its more easy for me to trust the
program
as well as the author.
kind regards
Theo Gottwald
Tel. +49 ((0)721) 9 66 33-00
Fax  +49 ((0)721) 9 66 33-99
E-Mail: the### [at] it-beraterorg
http://www.it-berater.org *
http://www.winrobots.de
Subject: Re: SMPOV 3.60 Distri 12 right now updated
Date: 4 Jan 2004 09:29:12
Message: <3ff82338@news.povray.org>
I got a reworked readme-file from Bob Hughes ( http://www.3digitaleyes.com )
thanks Bob all help is welcome!
And I added another small WinRobot to the distribution "Dr-SMPOV.exe".
This is a small Expert-Robot which will automatically check/correct all
Settings for
Local SMP-rendering if its started at the final location.
--Theo
Date: 4 Jan 2004 22:36:31
Message: <3ff8dbbf$1@news.povray.org>
Great, thanks Theo! And you have another e-mail with the final readme.txt
file editing I think it will undergo, by me anyway. Should be fairly
printable, and some of us know how printed instructions can help.
Date: 5 Jan 2004 02:18:14
Message: <5e3ivv8s2doq3bltf3parfrdnr44hf5o2o@4ax.com>
On 3 Jan 2004 18:41:08 -0500, Warp <war### [at] tagpovrayorg> wrote:
> distributing an adware version of POV-Ray
SMPOV is not version of POV-Ray.
Theo does not distribute any custom compile.
ABX
Date: 6 Jan 2004 08:01:15
Message: <3ffab19b$1@news.povray.org>
Maybe its a mixing betwen an shell and a pipeline :-).
You put renderjobs in at the right side.
And on the other side it produces pictures using all the resources between.
Actually I changed something around the "times.log", so benchmarking is more
easy and more exact.
I plan to release a new web-site showing "how to save time with SMPOV" (and
how not :-).
This shall include some benchmarks.
Date: 6 Jan 2004 08:03:59
Message: <3ffab23f@news.povray.org>
  I see. Sorry for the confusion.
Date: 6 Jan 2004 18:56:28
Message: <3ffb4b2c$1@news.povray.org>
You're welcome :-). I am quite happy that the POV-Ray community is so active
and so engaged
about these things.
Now to the news:
http://www.it-berater.org/shtmls/benchmark.shtml
is in a first version online. I think it should be intresting for everyone
who has been thinking about rendering things parallel, as it contains some
benchmarks with SMPOV, as well as theoretical conclusions on overhead and
rendering-time dependencies. Comments (especially on english grammar :-) are
welcome.
Date: 8 Jan 2004 09:47:30
Message: <cjameshuff-BA1676.09473608012004@netplex.aussie.org>
In article <3ffab23f@news.povray.org>, Warp <war### [at] tagpovrayorg>
The name doesn't exactly make that clear...especially when **POV is such
an established convention for custom POV versions. I guess it's too late
to change now...
Still, the lack of spyware doesn't strike me as an "amazing" feature,
and if it's really a *new* feature, meaning previous versions had
spyware, then I will never use the software.
http://tag.povray.org/
