POV-Ray : Newsgroups : povray.general : Termux !!! Server Time
13 Aug 2026 18:06:35 EDT (-0400)
  Termux !!! (Message 1 to 2 of 2)
Subject: Termux !!!
Date: 27 Jul 2026 08:40:00
Message: <web.6a6750988a93804f41f559c9d49cbb40@news.povray.org>
~/POV_Projects_SD/balcony $ uberpov -version
uberpov: cannot open the system configuration file
/usr/local/etc/uberpov/1.37/uberpov.conf: No such file or directory
UberPOV 1.37.1.0
This is an unofficial version compiled by:
 Termux User
Neither the POV-Ray Team(tm) nor the UberPOV maintainers are responsible for
supporting this version.
Copyright 1991-2015 Persistence of Vision Raytracer Pty. Ltd.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Built-in features:
  I/O restrictions:          enabled
  X Window display:          disabled
  Supported image formats:   gif tga iff ppm pgm hdr png jpeg tiff
  Unsupported image formats: openexr
Compilation settings:
  Build architecture:  armv8l-unknown-linux-androideabi
  Built/Optimized for: armv8l-unknown-linux-androideabi
  Compiler vendor:     gnu
  Compiler version:    clang++ 21.1.8
  Compiler flags:      -pipe -Wno-multichar -Wno-write-strings -O3 -ffast-math
-std=c++17
~/POV_Projects_SD/balcony $ povray -version
POV-Ray 3.8.0-beta.2.unofficial
 Termux
 The POV-Ray Team is not responsible for supporting this version.
Copyright 1991-2021 Persistence of Vision Raytracer Pty. Ltd.
Built-in features:
  Supported image formats:   gif tga iff ppm pgm hdr png jpeg tiff openexr
  Unsupported image formats: -
  Build architecture:  x86_64-pc-linux-gnu
  Built/Optimized for: arm-unknown-linux-androideabi
  Compiler vendor:     clang
  Compiler version:    arm-linux-androideabi-clang++ 21.0.0
  Compiler flags:      -march=armv7-a -mfpu=neon -mfloat-abi=softfp -mthumb
-fstack-protector-strong -Oz -std=c++14 -pthread
The Holy Trinity in one room !!!!
Subject: Re: Termux !!!
Date: 27 Jul 2026 09:40:00
Message: <web.6a675ef21599a63141f559c9d49cbb40@news.povray.org>
> UberPOV 1.37.1.0
>  Termux User
> Built-in features:
> -std=c++17
>  Termux
> Built-in features:
POV_Projects_SD/balcony $ megapov -version
megapov: cannot open the system configuration file
/usr/local/etc/megapov/1.2.1/povray.conf: No such file or directory
megapov: cannot open the user configuration file
/data/data/com.termux/files/home/.megapov/1.2.1/povray.conf: No such file or
directory
megapov: I/O restrictions are disabled.
Persistence of Vision(tm) Ray Tracer Version MegaPOV 1.2.1/ based on Pov-RAY
 3.6.1 (clang++ @ armv8l-unknown-linux-gnu)
 Termux User
 The POV-Ray Team(tm) is not responsible for supporting this version.
POV-Ray is based on DKBTrace 2.12 by David K. Buck & Aaron A. Collins
Copyright 1991-2003 Persistence of Vision Team
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd.
Primary POV-Ray 3.5/3.6 Developers: (Alphabetically)
  Chris Cason         Thorsten Froehlich  Nathan Kopp         Ron Parker
Contributing Authors: (Alphabetically)
  Steve Anger         Eric Barish         Dieter Bayer        Steve A. Bennett
  David K. Buck       Nicolas Calimet     Aaron A. Collins    Chris Dailey
  Steve Demlow        Andreas Dilger      Alexander Enzmann   Dan Farmer
  Mark Gordon         Christoph Hormann   Mike Hough          Chris Huff
  Kari Kivisalo       Lutz Kretzschmar    Jochen Lippert      Pascal Massimino
  Jim McElhiney       Douglas Muir        Juha Nieminen       Bill Pulver
  Eduard Schwan       Wlodzimierz Skiba   Robert Skinner      Yvo Smellenbergh
  Zsolt Szalavari     Scott Taylor        Massimo Valentini   Timothy Wegner
  Drew Wells          Chris Young
MegaPOV Contributing Authors: (Alphabetically)
  Christophe Bouffartigue  Thorsten Froehlich       Christoph Hormann
  Chris Huff               Jurjen                   Kari Kivisalo
  Nathan Kopp              Vahur Krouverk           William Pokorny
  Micha Riser              Wlodzimierz Skiba        Rene Smellenbergh
  Yvo Smellenbergh         Massimo Valentini        Thomas Willhalm
Other contributors are listed in the documentation.
Support libraries used by POV-Ray:
  ZLib 1.3.2, Copyright 1995-1998 Jean-loup Gailly and Mark Adler
  LibPNG 1.6.58, Copyright 1998-2002 Glenn Randers-Pehrson
  LibJPEG 8, Copyright 1998 Thomas G. Lane
  LibTIFF 4.7.2, Copyright 1988-1997 Sam Leffler, 1991-1997 SGI
Redirecting Options
  All Streams to console..........On
  Debug Stream to console.........On
  Fatal Stream to console.........On
  Render Stream to console........On
  Statistics Stream to console....On
  Warning Stream to console.......On
Parsing Options
  Input file: OBJECT.POV (compatible to version 3.61)
  Remove bounds........On
  Split unions.........Off
  Library paths:
    /data/data/com.termux/files/home/povray-3.6.1/include
Output Options
  Image resolution 100 by 100 (rows 1 to 100, columns 1 to 100).
  Output file: /storage/0000-0000/POV_Projects/balcony/OBJECT.png, 24 bpp PNG
  Graphic display......Off
  Mosaic preview.......Off
  CPU usage histogram..Off
  Continued trace......Off
Tracing Options
  Quality:  9
  Bounding boxes.......On   Bounding threshold: 25
  Light Buffer.........On
  Vista Buffer.........On   Draw Vista Buffer....Off
  Antialiasing.........Off
  Clock value:    0.000  (Animation off)
  0:00:00 Parsing
Possible Scene File Parser Initialization Error: Could not find file
 'OBJECT.POV'
Scene File Parser Initialization Error: Cannot open input file.
Total Scene Processing Times
  Parse Time:    0 hours  0 minutes  0 seconds (0 seconds)
  Photon Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Cloth Time:    0 hours  0 minutes  0 seconds (0 seconds)
  Mechsim Time:  0 hours  0 minutes  0 seconds (0 seconds)
  Render Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Postpr. Time:  0 hours  0 minutes  0 seconds (0 seconds)
  Total Time:    0 hours  0 minutes  0 seconds (0 seconds)
