POV-Ray : Newsgroups : povray.general : Empty value for variable Server Time
11 Jun 2026 02:43:58 EDT (-0400)
  Empty value for variable (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Empty value for variable
Date: 4 Feb 2023 08:10:00
Message: <web.63de58a35d560c7488a828ca6cde94f1@news.povray.org>
hi,
"yesbird" <nomail@nomail> wrote:
> Thanks a lot, it really works ! (on ver. 3.8 only),
ah, yes, forgot, sorry.  'optional' was new in 3.8.
> > (have a look at the 'queues.inc' for use of optional args)
> but I can't find this file anywhere, where did you get from ?
my own, on the wiki.  however, there's also a macro in 'pvars.inc' (on wiki)
which has only optional arguments.
regards, jr.
Date: 4 Feb 2023 08:25:00
Message: <web.63de5c185d560c744ad5859710800fb2@news.povray.org>
Thanks, I've found it, moreover structures are very useful itself :)
YB
Date: 4 Feb 2023 09:45:00
Message: <web.63de6e4f5d560c741f9dae3025979125@news.povray.org>
> Hi, guys !
> Is there a way to assign an empty value to variable, using something like 'None'
> in Python or NULL in C ? I would like to use it while passing parameters to
> macros, for more compact notation.
> Can not find any info in docs about it.
> Thanks in advance,
> YB
As jr pointed out, there are work-arounds.
I find the optional keyword, and its required commas to be awkward and clunky.
Can you store your macro parameters in an array?
Then the array will exist, but it might not have certain elements defined.  Then
you test each element in the size of the array
#declare SizeOfArray = dimension_size (Array, 1)-1;
#for (i, 0, SizeOfArray)
     #if (!defined (Array[i])
Just another option.
Date: 4 Feb 2023 11:05:00
Message: <web.63de81675d560c744ad5859710800fb2@news.povray.org>
Good idea, but 'optional' works fine for me, as I prefer to simplify the passing
process.
Date: 6 Feb 2023 13:30:00
Message: <web.63e146b35d560c7480f94ee210800fb2@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
Looks like there is some limitation on number of optional args:
#macro _vector(optional p1, optional p2, optional p3)
_vector(1, 2, 3) // OK
_vector(1, 2,  ) // OK
_vector(1,     ) // Error
I wonder how is your code works ?
YB
Date: 6 Feb 2023 13:45:00
Message: <web.63e14a775d560c7480f94ee210800fb2@news.povray.org>
Sorry, solution was:
_vector(1,,    ) // OK
Number of commas is matter
YB
Date: 6 Feb 2023 14:10:00
Message: <web.63e150485d560c741f9dae3025979125@news.povray.org>
> _vector(1,,    ) // OK
> YB
Yes, and that's why I find that method awkward.
There's also no way to write a macro with a variable number of arguments - it
has to be fixed.
But now that we have dynamic arrays, and indeed, mixed arrays, I think I'd opt
for passing an array of arguments in, and then having the macro analyze and
process the array.
We still don't have any means of checking what the data type is without aborting
the parsing phase with an error, so just be aware of that as well.
- BE
Date: 7 Feb 2023 01:15:00
Message: <web.63e1eb8d5d560c7488a828ca6cde94f1@news.povray.org>
hi,
> > _vector(1,,    ) // OK
> > YB
yes, optional value(s), not position(s).
for YB's benefit, I think that may be just because the parser is so .. lenient
elsewhere.  as you know, much POV-Ray code published here "skimps" on detail,
the ';' terminator is rarely used (or "taken serious" even, I feel), meshes and
such often omit the commas between neighbouring vector values etc.  in fact,
'box {your ears}' would have sufficed ;-).  with the macro it's simply that
w/out the commas, the parser would have no (literal) clue which of the args were
omitted.
> has to be fixed.
> process the array.
yes.  (dictionaries, too)
regards, jr.
Date: 7 Feb 2023 06:40:00
Message: <web.63e237c35d560c741f9dae3025979125@news.povray.org>
This is true, and we have some benefits and some hardships because of that.
We have lazy programming practices, black-box variable types and unknown
castings, parser "surprises", and bits of mystery code and loose ends all over
the internals.
>  in fact,
Oh, hardly.  There are days where you are simply unruly to the point where we
don't even know where to start figuring out what to do with you.   :P
> omitted.
Indeed.  No idea how such things are typically handled in other languages.
> > has to be fixed.
> > process the array.
See?   Positively flabbergasting.   An in public, no less.
You and your Dark Magic.
../jrEvilSpells.sh >/dev/null 2>&1
Date: 7 Feb 2023 09:05:00
Message: <web.63e25a105d560c74164c19e610800fb2@news.povray.org>
Thanks, they much more convenient to me.
YB
