POV-Ray : Newsgroups : povray.general : POV-Lab: plans and discussions Server Time
15 Feb 2026 09:55:50 EST (-0500)
  POV-Lab: plans and discussions (Message 25 to 34 of 44)
Subject: Re: POV-Lab: plans and discussions
Date: 12 Feb 2023 08:50:00
Message: <web.63e8ede11a3112301f9dae3025979125@news.povray.org>
"yesbird" <nomail@nomail> wrote:
> Hi, jr
> I've attached the most tasty maps to this message, btw, don't you know how to
> scale them properly, I mean map to object whole specter completely ?
> Reading manual:
> https://www.povray.org/documentation/view/3.6.1/335/
> and a lot of experiments with scaling gives no result.
> YB
Your color map for spring goes from 0 to 5.5
Your sphere has a radius of 10.
Normally (<--- get it?) we try to use values from 0 to 1 for everything and then
scale afterwards.
Since you're using a gradient pigment, and the sphere has a diameter of 20, then
you need to make that 5.5 fit across 20 evenly.
The only problem there, is that IIRC, POV-Ray just ignores all of those values
above 1 in the color map definition, and I don't think there's currently a
mechanism that can fix that (like scaling it).
So I plopped the color map into a spreadsheet, divided all of the indices by the
max, and pasted it back out into spring2.inc, then scaled it by 20.
Then the only other thing you have to take into consideration is the fact that
the sphere is at the origin, which means its left side extends over to x=-10.
So before scaling the unit color map, I translate it -x*0.5, and THEN scale it
by 20, so that it goes from -10 to 10.
I hope that helps illustrate how all of this works and how one should think
about it.
Download 'colormaps.png' (80 KB)
Preview of image 'colormaps.png'
Message: <web.63e8ee1d1a3112301f9dae3025979125@news.povray.org>
#version 3.8;
#include "jet.inc"
#include "hot.inc"
#include "winter.inc"
#include "parula.inc"
#include "turbo.inc"
#include "bone.inc"
#include "spring2.inc"
 location -z*30
 right x * image_width / image_height
 up y
 sky y
 look_at <0.00, 0, 0.00>
light_source{<0.0, 0.0, - 30.0> rgb <0.80, 0.80, 0.80>}
sphere {
 <0,0,0>, 10
             gradient x
             color_map {spring}
             translate -x*0.5
             scale 20
  finish {
   diffuse 1
Download 'spring2.inc.txt' (11 KB)
Date: 12 Feb 2023 09:10:00
Message: <web.63e8f28c1a31123088a828ca6cde94f1@news.povray.org>
hi,
cheers, got the zip, reading the posts, they may have to be re-created to use
the 0.0-1.0 range.
> So I plopped the color map into a spreadsheet, ...
I used a simple two colour map, at frequency 8, scale 1.5 (from unit sphere. :-)
regards, jr.
Download 'yb.png' (76 KB)
Preview of image 'yb.png'
Date: 12 Feb 2023 09:15:00
Message: <web.63e8f33c1a31123038010da810800fb2@news.povray.org>
> about it.
Thanks a lot for very professional and detailed explanation, now I will sleep
well at night :)
YB
Date: 12 Feb 2023 09:20:00
Message: <web.63e8f4a61a31123038010da810800fb2@news.povray.org>
Beautiful planet !
YB
Date: 12 Feb 2023 09:40:00
Message: <web.63e8f9761a3112301f9dae3025979125@news.povray.org>
> well at night :)
It's always the simple things that will truly drive you crazy.
Especially when there are no in-scene commands to fix them.
A few observations:
You have a "right" directive twice in your camera block.
You may want to read about the camera and the way it works since there are some
commands that will alter previous camera commands, so there is --- I'll call it
a preferred order of operations.  clipka and Le Forgeron have discussed this in
a few NewsGroup posts.
http://news.povray.org/53ff509f%241%40news.povray.org
Also, in case you need it:
http://news.povray.org/povray.binaries.images/thread/%3C5d95e6c3%241%40news.povray.org%3E/
I'd also try to establish some sort of standard indentation for things like
loops and textures and such - it will save a lot of time in debugging things
when you leave out a closing ) or }.   The POV-Ray parser will try to lump
everything after the missing symbol into the opening declaration, and the error
messages might be sending you on a wild goose chase.
I also tend to label my closing brackets so I know which #while #for #case #if
#macro I'm ending, or where in the tangle of texture, pigment, color_map,
pigment_map, finish, normal, function, texture_map, etc I'm at.
          color_map {
          } // end color_map
     } // end pigment
} // end texture
I'll even number them if I have a ton of nested flow control directives, so I
can keep them all straight.
With regard to the color_map, I'll say that this is just another example of
making the hard-coded data in your scene difficult to nearly impossible to
manipulate.   You might consider storing all of that data in an array, and then
building the color map from that.   Then you can mathematically manipulate the
index values any way you want.   It's also very useful in case you want to embed
"lines" into a map - in order to make grids, or bracket a region of something,
or fix an uneven-looking map that doesn't get interpolated the way that you want
visually.
That's also a LOT of color_map entries.   You might consider experimenting with
the interpolation between the first entry and the last, just assigning them 0
and 1 and see what happens.   There are also new blending modes in 3.8.
Lots of stuff.   Too much to take in all at once.  :)
- BW
Date: 12 Feb 2023 10:20:00
Message: <web.63e9031f1a31123038010da810800fb2@news.povray.org>
Thanks again, I will take into account everything, except commenting
start-end-of constructions. You know, it's a matter of taste, I'm prefer to have
as less text, as possible, and writing comments only if necessary.
YB
Date: 12 Feb 2023 10:37:19
Message: <63e907af$1@news.povray.org>
Op 12-2-2023 om 15:36 schreef Bald Eagle:
> visually.
This is interesting. Can you give an example on how to tackle that? I am
not sure if I understand correctly.
Date: 12 Feb 2023 12:05:00
Message: <web.63e91b451a31123088a828ca6cde94f1@news.povray.org>
hi,
> Thanks again, I will take into account everything, ...
re the camera stuff BE mentioned, made me think that assuming you/povlab knows
when a user also has POV-Ray installed, you could also perhaps make use of the
real-time render feature.  have put together a demo, but the compressed archive
is just over the limit; the "recommended" CLI options at top of scene file.
<https://wiki.povray.org/content/Documentation:Windows_Section_1#Real-Time_Raytracing>
<https://drive.google.com/file/d/11ePvkRUPHEmciusU_MNfvGs10lMX6Qck/view?usp=sharing>
regards ,jr.
Date: 12 Feb 2023 13:10:00
Message: <web.63e92a571a3112301f9dae3025979125@news.povray.org>
> Thomas
It's all here:
Download 'remapcolormap.png' (43 KB)
Preview of image 'remapcolormap.png'
