POV-Ray : Newsgroups : povray.general : POV-Ray Installation thread Server Time
18 Apr 2026 15:52:13 EDT (-0400)
  POV-Ray Installation thread (Message 41 to 50 of 61)
Subject: Re: POV-Ray Installation thread
Date: 15 May 2021 19:51:12
Message: <60a05e70$1@news.povray.org>
On 5/15/21 6:10 PM, Bald Eagle wrote:
> Sorry for the delay.
> Seems that somehow the povr script got deleted but the file was still there.
> I redownloaded the file and edited it to read:
> #!/bin/sh
> INSTALLDIR=/home/povray/povray-3.8.0-x.povr_b0bcf6c0
> export POVINC=${INSTALLDIR}/share/povray-3.8/include
> #export POVINI=${INSTALLDIR}/etc/povray/3.8/povray.ini
> unset POVINI
> ${INSTALLDIR}/bin/povray $@
> exit $?
> Seems to render the blob scene fine now.
> Not sure how THAT happened.
> Thanks for all the suggestions - that helped track down the issue.
> Maybe I will do some more fine tuning on this tomorrow.
> It's always something ridiculous.
Good to hear you've made progress.
I just popped back on because I just had the thought on the "failed to
fork" message first reported. One thing which could cause the OS to run
out of resources would be a script calling itself recursively - in an
infinite way. Maybe?
Bill P.
Date: 26 May 2021 17:01:36
Message: <60aeb730$1@news.povray.org>
Am 12.05.2021 um 15:20 schrieb jr:
> no one mentioned using/creating a (shell, etc) script to build yet, I think, so
> that'd be my advice.
Just throwing in a couple of $0.02 here:
We are intentionally NOT delivering a single shell script, because...
(1) This is a Unix version of POV-Ray, not specifically a Linux version.
(2) Although there are some well-established standards on Linux machines
by now, it is never guaranteed that a particular Linux machine uses,
say, apt for package management.
(3) What we really want is that magic
     sudo apt-get install povray
as the sole installation instructions for POV-Ray. That command, or
whatever equivalent may happen to work on your Linux distribution. Or
whatever equivalent mouse click may make that same magic happen. In
other words, our hope is that package maintainers for the various Linux
distributions will (continue to) "adopt" POV-Ray and compile it into
packages custom-tailored to fit the conventions of those very distributions.
The current steps of installing POV-Ray from the GitHub package has the
following components, which all have their specific place and reason for
being separate:
(1) Acquire the POV-Ray source code package.
This differs depending on where you want to get your source code package
from - you could download it via the GitHub web interface, you could
pull it in via `git` IF you have it installed but we don't know that,
you could have downloaded it to a USB stick and be carrying it over to a
machine on which you have no internet access... the possibilities are
endless. Also, obviously this can't be part of a simple script, because
you'll have to download that script first.
(2) `prebuild.sh`
This script converts the platform-agnostic source code distribution
package - the thing you'd download from GitHub - into a Unix-specific
source code package, populating the directory tree with additional files
created on the fly that would be a PITA to maintain manually, or move
Unix-specific files to places where we normally don't want
platform-specific clutter - all to placate subsequent build steps, which
use a (and arguably still THE) standard toolchain well established in
the Unix world.
This script is kept separate because the intention is to eventually not
have this run by the end user at all, nor even a package maintainer, but
rather by ourselves, to create a neat official POV-Ray v3.8 for Unix
source package once that version is finalized, that we can then put up
for download anywhere we please.
(3) Install any of the necessary prerequisites for you
There is no way to universally do this step for you. We don't know what
package managers you have installed. Is it apt? Is it rpm? Maybe even
opkg? nix? pacman? What is the name of the package? It may be different
depending on your Linux distro. Heck, we don't even know what shell
you're using. Is it bash? ksh? some other flavor? Nope. Not going there,
thank you.
(4) `configure`, `make` (or `make check`) and/or `make install`
This sequence of commands is THE leading de-factor standard in the Unix
world wherever software is still installed from source code (as opposed
to via package managers), period.
Date: 27 May 2021 02:25:00
Message: <web.60af3a742344a9a179819d986cde94f1@news.povray.org>
hi,
"...there is really precious little clear, methodical,
detailed information on how to install povray on a linux system, that is right
here on the POV-Ray website".  this comment by BE started off the thread.
you're right, UNIX != Linux, perhaps even more so for Debian derived stuff than
for others.
re providing build script(s) -- makes things repeatable, with little effort.
what's not to like?
why would anyone want 'apt' installed, if others package managers work equally
well?  by making the process depend on a specific Linux how would that help?
> being separate:
> (2) `prebuild.sh`
one could argue that (2) and (3) should be reversed.  agree on (4), how does
embedding that sequence (steps 2+4) in a script present "a problem"?
regards, jr.
Date: 28 May 2021 03:46:37
Message: <60b09fdd$1@news.povray.org>
Am 27.05.2021 um 08:21 schrieb jr:
> for others.
> what's not to like?
See above, particularly (2).
Yes, we could conceivably provide scripts for, say, "a typical desktop
Debian 10.0 install", "a typical desktop Ubuntu 21.10 install", "a
typical desktop Fedora 34 install", "a typical desktop FreeBSD 11.2
install", and so forth.
What we can't provide is a single one-size-fits-all script. It's simply
not possible.
Even if we'd go for the individual scripts approach, we'd need people to
maintan them. Each and every one:
- Every time we add a new package dependency (such as about to happen
with the FreeType library), someone would have to figure out the name of
that package on each and every distribution we try to support, and
modify those scripts accordingly. And test them.
- Every time a distribution we try to support releases a new version,
someone would have to test the existing script on the new distro
version. And maybe create a new script to adapt to any changes.
- Every time a user reports an issue with any of those scripts, someone
would have to troubleshoot that script. And once the root cause has been
solved, every single other script would have to be examined as well, to
see if they are subject to the same issue.
You see where this is going?
I'm not intending to discorage you. All I'm saying is, this is the sort
of problems associated with this approach, and this is why "we" (as in,
the POV-Ray main developers) WILL NOT DO THIS FOR YOU. If you or anyone
else wants this to happen, it will have to be a community effort. And it
should be a commitment, not only to create such scripts once, but also
stick with it and maintain them.
My take is that it is probably far more efficient to let package
maintainers do the job. People who know the peculiarities of their
distributions by heart, and who commit to keeping "their" packages
maintained. People who are also intimately familiar with the
`configure`/`make` standard process for compiling software from source
code. We provide them with the information what packages POV-Ray needs
and what switches its `configure` script accepts, and they figure out
the exact sequence of commands to produce binaries for a particular
distribution, ready to be installed by end users at a single click or a
single command line.
Which again leads us to:
As I said, "or whatever equivalent may happen to work on your Linux
distrubution. Or whatever equivalent mouse click may make that same
magic happen."
Whatever Linux, FreeBSD or other Unix(oid) distrubution you may be using
- YOU as the end user WILL be faminilar with YOUR package manager. You
WILL have an idea how to search for the POV-Ray package for your distro,
and you WILL know how to install a package once you've identified it.
If that is something you DON'T know, then how can you expect to be able
to install ANY software on your machine?
>> being separate:
>> (2) `prebuild.sh`
You're right about the ordering of (2) and (3) insofar as (2) requires
autoconf. As far as I know, that's the only prerequisite required for
that step though.
As for combining (2) and (4), see far above.
You don't just run `configure` and then `make`.
You pass several parameters to configure, starting with `COMPILED_BY=`.
Then some people prefer to specify `--prefix=`, while some others don't
care much about it, and some people need it because they're not
administrators. Then some people want to first run `make check` to
verify that compilation went fine, and only run `make install` after
that has been established, while others prefer to just run `make
install` straight away. Others may just want to build an experimental
version without installing it, and therefore refrain from running `make
install`. Not to mention certain cases for which we know that the usual
procedure does _not_ work, such as trying to build with Clang 3.4 while
using standard headers from gcc 4.6, which needs
`CXXFLAGS=-fno-fast-math` as a parameter to `configure` to work.
Also, some people may want to check for unexpected warnings after each
of those steps before proceeding to the next.
Yeah, sure, maybe we could create a script that accepts a bunch of
parameters to pass to `prebuild.sh`, another bunch to pass to
`configure`, yet another to pass to a first call to `make`, and finally
another to pass to a second call to `make`. And some parameter to
control whether you want to pause (with the option to abort) between steps.
Do you think that would make things a jot easier?
I don't.
What I do know is that it would be another assload of work to set up,
maintain, and curse to hell when things go wrong.
Date: 28 May 2021 04:02:59
Message: <60b0a3b3$1@news.povray.org>
Am 28.05.2021 um 09:46 schrieb clipka:
... oh, and I forgot: Depending on various circumstances, people will
want to run either `make install` or `sudo make install`. In the latter
case, they`ll typically want to run a simple `make` first, if they don't
run `make check`.
Or, on some odd quirky system, they may not be able to use `sudo`, and
instead need to start a new shell session with `su`, run `make install`
in there, and exit it again. In that case, running this as a spearate
step is, to the best of my knowledge, inevitable. Unless you want to run
all of the installation steps as superuser, but trust me, you don't want
to do that. If you were the type of person who would, you'd be logged in
as root all the time anyway.
If I can come up with all that stuff in just half a morning's worth of
time, imagine what good old reality would throw at such a script...
Date: 28 May 2021 04:10:00
Message: <web.60b0a4152344a9a179819d986cde94f1@news.povray.org>
hi,
first off, reading yr reply, I realise (and want to note) that we are, in fact,
"in violent agreement" on pretty much all the points.  (so I've taken the
liberty to snip much)
for all the reasons you gave etc.  the thread however, as I understood it, is
about building up a .. repository of scripts, snippets, related info on "foo"
required, etc.  all, again aiui, to be summarised + published on the wiki,
eventually.  a user-to-user resource.
> - Every time we add a new package dependency ...
> maintained.
I have attached the 'ldd' output for POV-Ray 3.7.0.8, as installed on a Debian
system, via 'apt-get'.  I leave it to you to .. rationalise the linking to
'pulseaudio' and other such.  ;-)
Download 'lddpov.txt' (5 KB)
Date: 28 May 2021 07:25:00
Message: <web.60b0d1e22344a9a11f9dae3025979125@news.povray.org>
Right.
One the one hand is the horror of what clipka describes, but on the other is
what I perceived as a tangible lack of concise organized instructions for doing
a basic install from scratch - right on the POV-Ray website, where someone would
expect it to be.
So, whatever it turns out to be, I think the realistic goal is to outline the
steps required for a successful install, along with some helpful caveats and
commentary about each step if necessary/desireable.
To illustrate this in part, TOK wrote, "And since Ubuntu's repository version
was already installed, I did not want to mess up things by running the sudo make
install command."
And if TOK doesn't want to screw things up, I'm betting a newbie isn't even
going to have the bravery to try.  I often don't know what "standard"
directories things get installed into, and from past threads, even those
locations are debated amongst experienced Unix/Linux users.
jr very kindly led me through a recent install of the povr branch, and somehow a
wrench got thrown into the works that puzzled everyone including WFP.  It got
sorted out - only because these people were "present", online, and asking
questions and running tests of their own in a timely manner.   That's a rare
luxury, and not something that's going to be available to some random person out
there thinking to themselves, "Hey, maybe I'll installl this POV-Ray thing..."
Which is exactly what we want people to do - install povray.
So I think the goal is not to have a bulletproof script, but to address the
problem of having next-to-no instructions on how to compile your own install,
and at least cut down on the number of forum posts required to get that to
happen with a minimum pucker factor.
I'm just gonna take a stab at that one and say that maybe there's the error and
render sounds - if those even happen in a linux install...
Date: 28 May 2021 08:35:00
Message: <web.60b0e2442344a9a179819d986cde94f1@news.povray.org>
hi,
damn, too easy..  </grin>  how about:
libFLAC.so.8 => /usr/lib/x86_64-linux-gnu/libFLAC.so.8
regards, jr.
Date: 28 May 2021 09:57:46
Message: <60b0f6da$1@news.povray.org>
Am 28.05.2021 um 10:04 schrieb jr:
>> maintained.
POV-Ray wants SDL for display.
SDL, as the full name "Simple Direct Media Layer" implies, does more
than just display.
SDL wants stuff, too.
Date: 28 May 2021 10:04:36
Message: <60b0f874@news.povray.org>
Am 28.05.2021 um 15:57 schrieb clipka:
>>> maintained.
>> a Debian
>> linking to
> than just display.
(If you squint your eyes and look closely, you'll find all of POV-Ray's
primary dependencies at the top of the list, right up to `libc`. All the
remaining stuff is pulled in by those primary dependencies, it would seem.)
