POV-Ray : Newsgroups : povray.general : Media, scattering, and radiosity Server Time
20 Jul 2025 14:12:48 EDT (-0400)
  Media, scattering, and radiosity (Message 1 to 2 of 2)
Subject: Media, scattering, and radiosity
Date: 31 May 2004 11:10:00
Message: <web.40bb4a79e36afb23a5b82adb0@news.povray.org>
I am interested in what the difference is between rendering media with
scattering with radiosity on/off.  I have looked through the source to see
how the scattering procedures work, but I don't understand the relationship
between them and radiosity.  Does radiosity include multiple scattering?
What is the difference between the physical propagation of rays through the
media?  I know this is vague, but perhaps someone will understand my
confusion.
Also, some of the documentation on scattering doesn't make sense.  It says
that having extinction any value other than 1 is not physical, but
according to the definition given, this simply means that the ratio of
scattered to absorbed rays is 1.  In normal radiative transfer methods,
there is a dimensionful quantity kappa which describes the amount of
scattering per unit mass of media.  Also, the optical depth is
dimensionful.  In POV ray there are no units involved (as is common in
computer science) so it appears that extinction is a parameter that
incorporates unit conversion as well as the traditional extinction
parameter.  Is this correct?
Thanks in advance,
Eric DeGiuli
[This was posted to .newusers a few days ago, but no one replied]
Subject: Re: Media, scattering, and radiosity
Date: 31 May 2004 22:56:53
Message: <cjameshuff-B5BB31.21565731052004@news.povray.org>
In article <web.40bb4a79e36afb23a5b82adb0@news.povray.org>,
> confusion.
Media does not scatter scattered light...that is, it is unaffected by
radiosity, a brightly lit object will not cast a glow on surrounding
media. Scattering media is illuminated only by direct light or by
deposited photons, both of which are attenuated by passage through the
media.
However, scattering media does affect radiosity...a bright area of media
will illuminate nearby surfaces. [1] And radiosity does simulate
multiple levels of scattering, the default being 3. You can use the
recursion_limit parameter to control this, but going above 3 or 4 is
usually a waste of processor time.
[1]: However, when I tested this, I found problems when the surface was
inside the media container. This was in MegaPOV, not a recent official
version, but it may exist there as well.
The documentation is not entirely correct. Values less than 1 are not
physically correct...transmitted light + scattered light adds up to more
light than hits the media. Values > 1 simulate media that absorbs as
well as scattering light.
It does not do any unit conversion. The appropriate values depend on the
dimensions and light intensities in your scene. I'm not really certain
what you're asking here...
http://tag.povray.org/
