POV-Ray : Newsgroups : povray.documentation.inbuilt : SOR documentation Server Time
7 Dec 2025 15:31:45 EST (-0500)
  SOR documentation (Message 30 to 39 of 69)
Subject: Re: SOR documentation
Date: 10 Sep 2025 09:30:00
Message: <web.68c17cd1251da1bcbe3debd925979125@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
.... how the internal cylinder bounding is being done. I
Check out Fig. 5, pg 11
https://www.cemyuksel.com/research/catmullrom_param/catmullrom_cad.pdf
We might have better luck if we changed how the bounding is done.
It also shows how I can create a set of control points where the curve
overshoots the control point polygon, and so I can use that to have the
interpolated curve cross over the rotation axis to see what happens.
I'll make a speculative prediction and say that the algorithm will try to take
the sqrt of that negative radius and fail - either throwing an error, or just
blanking out that portion of the curve - or the whole segment.
I'll probably have to convert most of the solver code to SDL and then use what I
get out of that to start to answer some other questions.
- BW
Date: 10 Sep 2025 11:16:51
Message: <68c19663$1@news.povray.org>
Thanks for reference! :-)
If you're referring to the sqrt I think you are, you've guessed
correctly! :-) I have a potential fix for it. The sqrt(-) along with
some fine detail in how std::min(), std::max() work when passed a -nan
value as the first argument vs the second argument cause the segment
blink out issue. Only limited testing thus far. Maybe I'll get to more
tonight.
I see some other not really wrong, but not optimal stuff happening too
with the cylinder segment bounding in y. Sort of as if it was written to
support on curve points in ascending or descending order less any
optimization for the y coordinates (The cylinders get taller and taller
as you have more segments instead of aligning with each of the segments
in y).
Bill P.
Date: 11 Sep 2025 05:58:33
Message: <68c29d49$1@news.povray.org>
> correctly! 🙂 I have a potential fix for it. The sqrt(-) along with some
> fine detail in how std::min(), std::max() work when passed a -nan value
> as the first argument vs the second argument cause the segment blink out
> issue. Only limited testing thus far. Maybe I'll get to more tonight.
Attached an image of some more testing. It includes the fix for the
segment blink out issue & that fix looks good thus far. For testing I
disabled all the point list sanity checking to see what works and not.
Not going to go through the image in detail, but in answer to your
question about on curve points going negative it looks like a no go
without a deep dive and probable re-work of the current code.
For reasons I don't understand, when I allow on curve points to go
negative the camera ray direction affects results. This shown in the
fourth row where the sor slowly disappears then reappears as rotated
about x.
The descending in y on curve points doesn't work at all.
Allowing the first and last control points to go negative is fine and I
plan to add that relaxing to the blank out fix for yuqk's next release.
You had mentioned not being able to flip the two control points in y.
Where everything I'd tried to that point seemed to work. You also
mentioned this bit of code in sor.cpp :
if ((fabs(P[i+2][Y] - P[i][Y]) < gkMinIsectDepthReturned) ||
     (fabs(P[i+3][Y] - P[i+1][Y]) < gkMinIsectDepthReturned))
throw POV_EXCEPTION_STRING("Incorrect point in surface of revolution.");
I'm finding it is this run time check which sometimes doesn't allow
control points flipping in y. For yuqk what will be in the next release
is some added error text when that check trips so it is easier to
understand what is wrong.
Error! Problem point in sor segment 0 point set.
fabs(P[2][Y] - P[0][Y] || fabs(P[3][Y] - P[1][Y])
fabs(0.5 - 0.5 || fabs(0.9 - 0) < 4.44089e-08
The center images in the bottom two rows(*) of the attached image trip
this check and error. So, that code is catching some 'particular' cases
where given the control point locations relative to other on curve
points doesn't render correctly.
(*) Those rows are start the control points at one extreme and slowly
flip them to the opposite extreme in y moving left to right in the lower
two rows.
So with the segment blink out fix, it does look like more could be
allowed as valid point sets for the sor & yuqk will adopt those
relaxations. The shapes with negative control points do break up more
often, but as we found this can happen today with certain point lists.
(I've not really looked at intersections and differences as yet)
Bill P.
Aside: Somewhere I should mentioned too that that blink out fix corrects
the blink out, but in certain cases it also slightly corrects bounding
cylinders where due how min/max work there was no blink out. In other
words some fringe fixes/differences might appear too due the blink out fix.
Download 'sor_testing.png' (114 KB)
Preview of image 'sor_testing.png'
Date: 11 Sep 2025 10:40:00
Message: <web.68c2de77251da1bcf34d8a9e25979125@news.povray.org>
So what did you do?
in line 1082
x[n] = sqrt(r[n] * (r[n] * (r[n] * A + B) + C) + D);
I'd suggest changing that something like
x[n] = sqrt( fabs(r[n] * (r[n] * (r[n] * A + B) + C) + D) );
I'd suggest the above, if you haven't already done that.
Also, it may have something to do with calculating the intersections.
There's a check on Radius2 that I saw, so see what happens when you change:
Lines 1110-1111
Radius1 = xmin;
Radius2 = xmax;
to use fabs()
> about x.
Not surprising - all the checks for the control point order need to be
rewritten.
I'll have to do some more experimenting when I get the chance.
> You also
That def seems to be related to what you're seeing in those last 2 rows - since
the cp's are nearly coincident in y.
Do you think as a quick fix, we could just add -ymin to all the values to
translate everything into the first quadrant, starting at y=0, and then
translate everything back after the math gets done?
Very nice that some of this is getting worked out after 30 years.  :)
- BW
Date: 11 Sep 2025 22:27:06
Message: <68c384fa$1@news.povray.org>
> So what did you do?
The current fix is:
     if ((r[n] >= y[0]) && (r[n] <= y[1]))
//      x[n] = sqrt(r[n] * (r[n] * (r[n] * A + B) + C) + D);
         double tmpVal = (r[n] * (r[n] * (r[n] * A + B) + C) + D);
         if (tmpVal>=0.0)
             x[n] = sqrt(tmpVal);
         else
             tmpVal = std::abs(tmpVal);
             x[n] *= -1.0;
As for the bounding suggestion, I don't know. Of note is that the
Radius1 value is never used that I see.
Something I did try was faking a user bounding radius multiplier option.
In some configurations where only a subset of the on curve points were
negative in x. It often helped with apparent clipping - but there always
remained some issue with the the ray directions relative to the overall
sor - where all or part of sor 'segment(s)' would drop away (this an
issue apart from the entire-segment blink out issue up top).
My wild guess. There are internally calculated A,B,C,D values used for
the quadratic eqn solved while setting the two bounding radii values.
Those calculated values involve the x values as given for the sor point
set. Maybe something could go 'more right' there when negative values
are present - I don't know.
Bill P.
Date: 26 Sep 2025 10:45:00
Message: <web.68d6a6dd251da1bc98de4e8625979125@news.povray.org>
I'm still working on unraveling the source code for
bool Sor::Intersect, line 239 in sor.cpp
Line 276 has the interesting expression:  r0 = P[X] * D[Z] - P[Z] * D[X];
and I wasn't sure what that exactly did, especially since the comment that
precedes it is
 /* Get distance of the ray from rotation axis (= y axis). */
and that didn't look like any distance formula that I've ever seen.
The minus sign certainly helped obscure its meaning and purpose.
Apparently it's a sort of 2D cross-product, or "perp-product"
https://s.goessner.net/articles/crossProductHarmful.html
Also being covered in Graphics Gems IV:
Hill, F. S., Jr., The Pleasures of `Perp Dot' Products, p. 138-148.
And since I'm speculating that there are other examples this to be found in
source, I'm documenting this fully here for future reference.
immediately following that, I have a comparison of the length of the ray
direction vector D with some variable "a", which due to poor source code
documentation, I have no idea what "a" exactly is, or why if they are equal that
r0 has to get divided by the sqrt of a.
    #if ((a = Dx * D.x + D.z * D.z) > 0.0)
            #local r0 = r0/sqrt(a);
I also have Entry->A (through D) which I need to figure out.
- BW
Date: 29 Sep 2025 10:10:00
Message: <web.68da924f251da1bc44a8a4be25979125@news.povray.org>
I have a functional, if not yet rigorous understanding about the ray-radius
intersection test(s).  I am hoping to understand it completely enough to make
one of my explanatory diagrams.
>     #end
I believe I see what's going on here.
in c++, == is a comparison.
= is an assignment.
So the #if line is simultaneously assigning the evaluation of the expression to
a, and then comparing it's value to 0.0.
This has to do with the arrow operator, or "Class Member Access Operator".
In sor.h, we have
struct Sor_Spline_Entry_Struct final
    DBL A, B, C, D;
and
struct Sor_Spline_Struct final
    int References;
    SOR_SPLINE_ENTRY *Entry;
    BCYL *BCyl;                 /* bounding cylinder.                  */
So "Entry" is a pointer to SOR_SPLINE_ENTRY, which has class members A through
D.
"Entry->A" is a whole identifier, which snakes through the 2 structs to identify
and use A.
and
class Sor final : public ObjectBase
    public:
        int Number;
        SOR_SPLINE *Spline;      /* List of spline segments     */
.... etc.
So A through D have something to do with the spline segments.
I just don't "see" where they come from or what their exact meaning is.
Perhaps somewhere else farther upstream in the code is a place where the control
points get grouped in sets of 4, and so A through D would be sets of control
points.
- BW
Date: 30 Sep 2025 15:15:00
Message: <web.68dc2b83251da1bc44e64d2825979125@news.povray.org>
> points.
And this is the challenge of trying to do this piecemeal, in fits and starts
during random available 15 min opportunistic time slots.
Just a few lines above that is:
/* Step through the list of intersections. */
    for (j = 0; j < cnt; j++)
        /* Get current segment. */
        Entry = &Spline->Entry[intervals[j].n];
and I'm kinda guessing that intervals comes from insert_hit in
https://github.com/POV-Ray/povray/blob/master/source/core/bounding/boundingcylinder.cpp
So that's my current working theory.
Date: 2 Oct 2025 08:55:00
Message: <web.68de75cf251da1bce2c47eda25979125@news.povray.org>
I also cannot find the following 2 functions in the code repository.
I can't search without being logged in, and username/pswd are scribbled down
somewhere at home.
    MInvTransPoint(P, ray.Origin, Trans);
    MInvTransDirection(D, ray.Direction, Trans);
Anyone?
Date: 2 Oct 2025 09:15:00
Message: <web.68de79b6251da1bc6ddd22546cde94f1@news.povray.org>
hi,
> somewhere at home.
> Anyone?
core/math/matrix.h has the prototypes, hth.
and thx re other thread.
regards, jr.
