POV-Ray : Newsgroups : povray.documentation.inbuilt : SOR documentation : Re: SOR documentation Server Time
18 Jul 2026 20:08:30 EDT (-0400)
Date: 8 Sep 2025 07:10:00
Message: <web.68beb92d251da1bc1f9dae3025979125@news.povray.org>
> As shown, when I use cutaway_textures, I DON'T see the expected
> interior_texture, but the surface texture {}.  And when I use sor {open}, I do
> not see a hollow infinitely thin surface, I get a solid object sliced in half.
Also, I'm curious as to why the cutaway_textures feature requires the use of an
untextured object as a cutter to be able to function properly.
One would reasonably expect that we should be able to use any object.
If, as per wiki documentation, the cutaway_textures feature result is based on
insidedness tests, then the texture of the cutter should be irrelevant.
- BE
