POV-Ray : Newsgroups : povray.documentation.inbuilt : Command line switches and ini file settings : Re: Command line switches and ini file settings Server Time
13 Apr 2026 10:42:05 EDT (-0400)
Date: 10 Feb 2006 13:20:00
Message: <web.43ecd6e7b36d0cd6be920ef30@news.povray.org>
ingo <ing### [at] tagpovrayorg> wrote:
> in news:web.43ebacf5dc73d596be920ef30@news.povray.org Jon Buller wrote:
> > Is there anyplace where all the command line switches and ini file
> > settings are documented?  The stuff at
> > http://www.povray.org/documentation/ seems a bit lacking...
> 3.1.2 Command-line options
> close to anything you can put on the commandline you can put in an INI-
> file.
> When you have access to the windows help (chm) file, in the index search
> for anything with a "+", these are the shortcuts for command-line options.
> Ingo
Ahh, yes, but I've been switching back and forth between a UNIX box and a
windows box, and most of my coding / searching was on the UNIX box, using
firefox pointed at povray.org/documentation.
I probably should have asked Google and limited the site to the
documentation section of povray.org though.  I always think of the better
and simpler ways of doing things after ranting.  I suppose that isn't
really the inbuild documentation either, but I didn't see a better place to
post.
I think the main point I was trying to make is that "Introduction" is not a
good name for that section in the online docs, and the "see also" links are
not particularly good at directing you to that section if you are somewhere
else.  I also thought that the windows stuff was generated from the same
source as the online HTML was.  I now see that there are some reasonable
differences, and that it was a poor assumption as well.
Jon
